Sppon LSD for H22A
Old Apr 26, 2003 | 12:11 AM
mugencl1's Avatar
Default Sppon LSD for H22A
Please check this link if interested, http://cgi.ebay.com/ebaymotors...&rd=1
I have a same lsd installed in my euro r. The car handle much better than the stock lsd.
Old Apr 26, 2003 | 06:06 AM
satan_srv's Avatar
Default Re: Sppon LSD for H22A (mugencl1)
I'd say it's 90% likely that it will only fit in an LSD tranny, and not any USDM non-LSD casings...the differentials are different sizes..
PS link doesn't work..
Old Apr 26, 2003 | 08:52 PM
kotetu's Avatar
Default Re: Sppon LSD for H22A (satan_srv)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by satan_srv &raquo;</TD></TR><TR><TD CLASS="quote">I'd say it's 90% likely that it will only fit in an LSD tranny, and not any USDM non-LSD casings...the differentials are different sizes..
PS link doesn't work..</TD></TR></TABLE>
What about a JDM 4th gen tranny casing?
Old Apr 27, 2003 | 12:40 AM
mugencl1's Avatar
It will also fit a 4th - 5th gen non-lsd tranny. Because I sold my stock lsd to a guy in usa. He already install it into his non-lsd usdm tranny (h22a1). He told me it just a simple swap and bolt in job.
Old Apr 27, 2003 | 05:51 AM
crxludeT66's Avatar
will it fit in a 92 accord tranny?
Old Apr 27, 2003 | 06:06 AM
mugencl1's Avatar
Default Re: Sppon LSD for H22A (crxludeT66)
What is your engine? h22 or f22? It will fit both no matter what year.
Old Apr 27, 2003 | 04:11 PM
satan_srv's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mugencl1 &raquo;</TD></TR><TR><TD CLASS="quote">It will also fit a 4th - 5th gen non-lsd tranny. Because I sold my stock lsd to a guy in usa. He already install it into his non-lsd usdm tranny (h22a1). He told me it just a simple swap and bolt in job.</TD></TR></TABLE>
That's funny cause I sold an OEM one to a guy and it totally didn't fit. And we couldn't fit a quaife into the LSD tranny casing...
Old Apr 27, 2003 | 04:12 PM
satan_srv's Avatar
how many bolts does it have for the ring gear?
Old Apr 27, 2003 | 04:47 PM
HotWheelz's Avatar
jdm tranny lsd's only fit jdm tranny casings.. all othe lsd's will only fit (USDM cases) not JDM equivalent.
Joel is right.
Old Apr 27, 2003 | 05:32 PM
satan_srv's Avatar
Default Re: Sppon LSD for H22A (HotWheelz-turboh22dx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HotWheelz-turboh22dx &raquo;</TD></TR><TR><TD CLASS="quote">jdm tranny lsd's only fit jdm tranny casings.. all othe lsd's will only fit (USDM cases) not JDM equivalent.
Joel is right.</TD></TR></TABLE>
thanks...I wou;d guess this spoon lsd has 14 bolts...while USDM diffs have only 10.
Old Apr 28, 2003 | 03:30 AM
mugencl1's Avatar
Both stock Euro R's LSD and Spoon LSD have only 10 bolts.
Old Apr 28, 2003 | 04:10 PM
satan_srv's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mugencl1 &raquo;</TD></TR><TR><TD CLASS="quote">Both stock Euro R's LSD and Spoon LSD have only 10 bolts.</TD></TR></TABLE>
Interesting....the 4th gen OEN LSD has 14...
So the euro-r only has 10? That's crazy. I have a euro-r tranny I may actually be interested in this...but the $$$$ and my euro-r tranny has 0 miles on it..
Old Apr 28, 2003 | 04:12 PM
ludedudesi's Avatar
hey joel where could i find me a euro R tranny? the gears are shorter than 4th gen vtec correct??
Old Apr 28, 2003 | 04:24 PM
satan_srv's Avatar
Default Re: Sppon LSD for H22A (ludedudesi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ludedudesi &raquo;</TD></TR><TR><TD CLASS="quote">hey joel where could i find me a euro R tranny? the gears are shorter than 4th gen vtec correct??</TD></TR></TABLE>
Yes. Well 2nd and 3rd are...1 is 5th gen 4 is 4th gen 5th is type-s
I got mine from the UK, but you woul dhave more luck from Japan.
Old Apr 28, 2003 | 07:57 PM
mugencl1's Avatar
So the euro-r only has 10? That's crazy. I have a euro-r tranny I may actually be interested in this...but the $$$$ and my euro-r tranny has 0 miles on it..</TD></TR></TABLE>
The stock LSD from the Euro R tranny is just a very mild setup. It can't compare to the clutch type LSD like Spoon.
Old Apr 28, 2003 | 08:00 PM
satan_srv's Avatar
The stock LSD from the Euro R tranny is just a very mild setup. It can't compare to the clutch type LSD like Spoon.</TD></TR></TABLE>
I agree. I had a kaaz before, but I had to go with the euro-r for the gearing. The gearing is a big improvement over a prelude tranny isn't it? in your opinion...
Old Apr 29, 2003 | 12:13 AM
mugencl1's Avatar
Sure I drove an Accord SIR-T before. But changed to Euro R since it released. The closer gear ratio help to keep the rpm a bit. But it reduce the top speed also. I can only do 250km/h at 7200rpm with my current setup. I hop I can improve it by using an AEM EMS to tune my car and rise the limit to 8500rpm.
Old Apr 30, 2003 | 02:40 PM
satan_srv's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mugencl1 &raquo;</TD></TR><TR><TD CLASS="quote">Sure I drove an Accord SIR-T before. But changed to Euro R since it released. The closer gear ratio help to keep the rpm a bit. But it reduce the top speed also. I can only do 250km/h at 7200rpm with my current setup. I hop I can improve it by using an AEM EMS to tune my car and rise the limit to 8500rpm.</TD></TR></TABLE>
the 5th gear on the euro-r is 0.812 isn't it? That's better than a 4th gen prelude tranny I thought...
Old Apr 30, 2003 | 07:09 PM
mugencl1's Avatar
the 5th gear on the euro-r is 0.812 isn't it? That's better than a 4th gen prelude tranny I thought...</TD></TR></TABLE>
Yes thats why it slows top speed. Did you put on the euro-r tranny yet? What flywheel you currently use? I am having JUN 11lbs, but I also ordered a fidanza 8lbs. What you think to keep the JUN or swap with the fidanza?
Old Apr 30, 2003 | 08:12 PM
satan_srv's Avatar
Yes thats why it slows top speed. Did you put on the euro-r tranny yet? What flywheel you currently use? I am having JUN 11lbs, but I also ordered a fidanza 8lbs. What you think to keep the JUN or swap with the fidanza? </TD></TR></TABLE>
oh I see what you mean...you get to top speed SLOWER.....right....of course..it's fairly long...
I haven't put it on yet...engine goes in friday or monday. Is the euro-r noisy? I heard it may have straight cut gears?
I have a clutchmasters 8.5lb flywheel I like it. But when I had a knifeedged crank it really dropped rpms fast on the street. I have a non-knifeedged crank now so it should be perfect.
pcguy760
Transmission & Drivetrain
Oct 17, 2008 11:24 PM
miguel91911
Feb 22, 2007 04:10 PM
Drew17th
Jan 24, 2007 02:21 PM
F120man
Jul 3, 2003 12:11 PM
dkasakitis
Mar 19, 2003 04:39 AM
