downforce created by rear wing and front end?
Ah....downforce....
My ATR has a rear spoiler as well. It is also equipped with some sort of sensor (probably a variable resistor) hooked up to one of the rear-suspension rods so that it can compensate for the front lights (krypton) with different loads in the trunk. This feature is standard on ATR's for the purposes of not blinding traffic when there is more weight in the trunk.
Now, I assume that the ITR has the same feature (?) but if so you could do the following:
1) Raise car to get access underneath and locate this 'sensor'.
2) Hook up two wires and route into the car.( these wires will be going to a controller (ECU?) for sure but I dunno which one/location...)
3) Hook up a VDC meter (any cheap one will do) and measure VDC at , let's say, 50kmh, 100kmh 150kmh and 200kmh. Record all voltages.
4) Now,whith engine running idle and standing still put various weights in the trunk that give the same VDC readings...Voila, ....downforce measured.
I was planning to do so myself some time ago but kinda lost interest.
Good luck~!
Good luck~!
I read on another message board that the rear wing produces 300lbs at 90mph and the front end produces 190lbs. That seems a little unbelievable though.
AcuraRacer112
11
Oct 10, 2002 09:28 AM
