1998+ Accord Gen6 Hi-Flow Fuel Pump
Old Apr 25, 2003 | 06:52 PM
MR_CHAD's Avatar
New User
Default 1998+ Accord Gen6 Hi-Flow Fuel Pump
Any one find or know of a high volume in tank fuel pump that will work in a 98+ Accord 4cylinder?
The 94-97 Accords can use the Walbro 255 unit; can the 98+ cars?
Thinking of running N20 and would like to upgrade fuel system before install.
Old Apr 26, 2003 | 04:57 AM
niedejb's Avatar
Default Re: 1998+ Accord Gen6 Hi-Flow Fuel Pump (MR_CHAD)
What size shot are you looking at. The stock fuel system is way rich to begin with. If youre looking at a 50 shot or less you wont need the pump.
Old Apr 26, 2003 | 05:19 AM
MR_CHAD's Avatar
New User
Default Re: 1998+ Accord Gen6 Hi-Flow Fuel Pump (niedejb)
I was thinking of starting out with a wet kit, single fogger, and a 35-50 shot.
Latter after building a new engine, I was hoping to add a 75-100 shot: direct port.
So I figured a new high flow fuel pump seems like good insurance.
However, did some searching looks like their aren't any higher flow (190-255) type pumps out yet for a 98+ Accord.
Old Apr 26, 2003 | 06:11 PM
iam7head's Avatar
"Latter after building a new engine"
what do you have in mind??
you can use the walbro 255lph intank fuel pump like how i have it in my turbo accord. direct fitment, installed mine in less than a hour.
you prolly dont need that big of the fuel pump to begin with, start getting a Fuel Pressure Regular and Fuel pressure gauge, so you can see how much psi is in your system. You prolly will play around and adjusting it to get it lean out/rich.
Old Apr 26, 2003 | 06:13 PM
iam7head's Avatar
Default Re: 1998+ Accord Gen6 Hi-Flow Fuel Pump (iam7head)
when using n2o, it's good to get timing management unit, or at least retard it a bit accord to application.
Colder sparkplugs,etc
Old Apr 28, 2003 | 05:25 PM
MR_CHAD's Avatar
New User
iam7head,
Are you running a Walbro in a 6th gen?
Do you think a 50shot and FPR would be enough?
Would I benefit from having my injectors blueprinted or should I upgrade to something better from RC?
Old Apr 28, 2003 | 06:00 PM
iam7head's Avatar
you prolly don't need bigger injector or 255 fuel pump, you can spark a flame in the muffler with it on NA accord lol.
FPR, Fuel pressure gauge, try it if they are not enough you can get the 192 warlbro pump.
Old Apr 28, 2003 | 06:02 PM
iam7head's Avatar
oh yeah i have a turbo setup with the walbro 255, i use the fuel pressure regualor to control the rate, lol.
I ran super rich when i first got the fuel pump on, black cloud coming out my muffler lol.
you dont need to drop the tank on 6th gen=super doper easy installation.
kamAccord
Aug 15, 2009 10:55 PM
mozzandherb
Apr 2, 2006 03:59 PM
fastsohc
Nov 16, 2004 09:21 AM
billk2k
Sep 15, 2003 07:21 AM
Excelerate
Oct 4, 2002 10:46 AM
