1G CRX swap questions and compatibility
Ok i'm getting an 87 CRX Si for 50 bucks that has a rod through the block and needs a new front fender. I am going to attempt to build a race car using a sohc base 94 1.6 liter i have laying around the shop. Before i attempt to do this i need some advice and questions answered if possible:
1. How much work will be involved in putting the 94 engine in the CRX?(will it bolt up to the CRX's tranny, wiring issues, etc)
2. I was think about using the 94 wiring harness with the car and just using the 94 ecu also since i have all these parts here?
3. I will probably fab all the mounts if i have to, but any other issues i may run into? (94 axles fit into the 87 hubs?)
thanks for any input
see also http://www.hasport.com site for parts and gen swap guidelines...
mattharrington
Jun 19, 2007 10:23 PM
