Help with Clifford and Viper alarms!
My friend and I have a Clifford Concept and Viper alarm. We want to swap alarms, but don't want to go through the hassle of reinstalling the entire alarm in both cars, splicing wires to ignition, etc. I have the Viper install manual, but can't find one for the Clifford Concept. Does anyone know if the two alarms have similar plug-in harnesses to the brain? I need to know such things as
- do both have the same number of harnesses plugging into the brain?
- do each of the harnesses have the same, or similar, number of pins?
- etc.
Basically, I need to know how easy it is to swap the 2 alarms by just swapping the CPU units. If someone can point me to a Clifford Concept install manual, it'd be of great help. Any help is much appreciated! Thanks.
- etc.
they do not..unless its the newer alarms like when viper bought out clifford. ...you don't have to splice all ne wires.... just cut the one you used on each alarm and solder the new one in.....I know of a website that you can find all the manuals on and it's http://www.directechs.com...there are hella manuals on there and also vehicle diagrams....it will ask you to enter a code try 122t...that's goodguys old password...but don't know if it still works or not......
Thanks. The 2 alarms is a Clifford Concept100 and a Viper 500ESP. Both were purchased and installed quite a while after DEI's purchase of Clifford. I'll take a look at the site. Anyone else?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TrblPinoy1 »</TD></TR><TR><TD CLASS="quote">they do not..unless its the newer alarms like when viper bought out clifford. ...you don't have to splice all ne wires.... just cut the one you used on each alarm and solder the new one in.....I know of a website that you can find all the manuals on and it's http://www.directechs.com...there are hella manuals on there and also vehicle diagrams....it will ask you to enter a code try 122t...that's goodguys old password...but don't know if it still works or not......</TD></TR></TABLE>
im pretty sure your not supposed to give out that password.. that was our old on for my store also (not goodguys) but we have changed ours.. you can download all the manuals from dei website as well at http://www.alarms.com
