Help!!!! please asap...
Old Apr 25, 2003 | 01:32 PM
binkster's Avatar
Default Help!!!! please asap...
We have the shock and spring installed into the engine bay but we are having a problem with the fork attaching to the wheel. The notch on the shock isnt lineing up with the fork right. how do you rotate it so that they line up.
Thanks......
Old Apr 25, 2003 | 01:35 PM
badCRX's Avatar
New User
Default Re: Help!!!! please asap... (binkster)
Loosen that 14mm bolt that hold the two together and just twist and turn til it goes into place. It may be best to take it all out and set it up before putting it into place.
Old Apr 25, 2003 | 01:37 PM
binkster's Avatar
Default Re: Help!!!! please asap... (badCRX)
when its compressed?
Old Apr 25, 2003 | 01:46 PM
badCRX's Avatar
New User
your settings won't allow me to return IM's.
Do you have the forks on the right sides? Not sure if that makes a diff, but flat goes to the rear and curved goes towards the front.
If you put it all together outside of the car, you can still put it together. Just have someone step on the hub and push the lower control arm down so that you can get the fork over it.
gezer
11
Jul 23, 2004 03:22 PM
binkster
Apr 26, 2003 06:49 AM
binkster
Apr 25, 2003 02:03 PM
