F*CK. wrong pistons=8bent intake valves.
Old Apr 25, 2003 | 12:44 PM
baonest1's Avatar
Default F*CK. wrong pistons=8bent intake valves.
well after trying to find out why my car would turn back on, me and "v-attack" decided to pull the head. so we did and we notice that the valves were off target. the block is an LS block with JE11.5 pistons.
i called JE back when the shop was assembling the block and ask if it was ok to run these pistons with an ITR head, they said yah its ok. well its not. now someone tell me why this happened. im sure its cuz the pistons were wrong.
are these pistons still usable, could i sell them? im not sure if all are bent, but im still replacing all 8 valves. dealer quoted me about $20 per vavle, probably like $15-17 at dealer cost. should i go with the ferrea valves, how much do they cost
Modified by baonest at 5:17 PM 4/25/2003
Old Apr 25, 2003 | 01:03 PM
Jeff C's Avatar
Default Re: F*CK. wrong pistons=8bent intake valves. (baonest)
Ouch. What was your timing set at? Are both the intake and exhaust valves the same diameter?
Edit: I got another look. Something was way off!
Old Apr 25, 2003 | 01:08 PM
pills_PMD's Avatar
who put the timing belt on?? was it properly aligned?? was EVERYTHING at TDC?
Old Apr 25, 2003 | 01:16 PM
baonest1's Avatar
Default Re: (pills_PMD)
yah. everything was aligned. timing belt was put on by v-attack and i. everything lined up perfectly at TDC.
how could dist. timing do this??
Old Apr 25, 2003 | 01:47 PM
ScottEK's Avatar
Default Re: (baonest)
They're talking crank/cam timing not distributor timing.
Old Apr 25, 2003 | 01:50 PM
Jeff C's Avatar
Well according to the old crvtec.com, (with a stock b20 block and any cam larger than itr's) you could not adjust your timing more than 2deg either way or else the valves would touch the pistons. I realize that this is not your situation, but I thought maybe it would be along the same lines. For example, maybe you got a set of JE nonvtec pistons (if there is such a thing) for a ls block and the valve reliefs were not large enough and your timing was at +/- 2deg. This may not make any sense. It was just a thought.
Old Apr 25, 2003 | 02:15 PM
baonest1's Avatar
Default Re: (Jeff C)
jeffC i beleive you are right tho. a friend came over and told me i can get the reliefs cut out more. i dont know, i could do that and save the time of basically building another block. or get the right pistons.
when i first started the project. i wanted an all motor LS (no flames please), then i got the ITR head. i called JE. told them i am putting an ITR head instead of LS head. told them i have ITR valves too. and they said that there is no problem.
man i should have known. all this time when the car was running it was just nicking the piston top, but when we took it to like 4.5-5K it just did its job
edit: its worth a try to call JE and tell then the prob. and see what they can do.
Modified by baonest at 6:27 PM 4/25/2003
Old Apr 26, 2003 | 01:32 AM
racecarpete's Avatar
just wondering, why didn't you clay the motor? it would have prevented this.
Old Apr 26, 2003 | 05:44 AM
baonest1's Avatar
Default Re: (SilverCivic2k)
i did clay the motor. i put clay in the releifs. and on the top of the pistons, but not right behind the reliefs cuz i trusted that these were the right pistons. it all comes down to my fault really for not knowing that LS pistons will not work with ITR valves. never trust anyone these days. they will tell you **** just to get off the phone with you.
Old Apr 27, 2003 | 07:08 PM
baonest1's Avatar
this is how i clayed the motor. i called JE on friday but i got cut off, so i am going to try to call them tomorow. and let them know what happened. hopefully they can do somthing about it. i just dont know if i should flycut the pistons, or get a new set.
Old Apr 27, 2003 | 10:49 PM
Damn, to be honest if you have the original salesmans name i would raise some hell. Thats a pretty expensive screw up they cost you, they should be held reliable or at least work with you somehow.
Note to self: clay behind valve reliefs for extra insurance.
Old Apr 27, 2003 | 11:12 PM
ID_ten_T's Avatar
you should call autoraceparts.com (561) 840-1878 about new valves. i just got some rev valves for 14.50 each. they also quoted me for some ferrera valves (16 each, i think). great service, got here quick.
Old Apr 28, 2003 | 05:35 AM
baonest1's Avatar
Default Re: (ID_ten_T)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ID_ten_T &raquo;</TD></TR><TR><TD CLASS="quote">you should call autoraceparts.com (561) 840-1878 about new valves. i just got some rev valves for 14.50 each. they also quoted me for some ferrera valves (16 each, i think). great service, got here quick.</TD></TR></TABLE> how do the rev valves compare to stock? i know the ferrea ones are good.
Old Apr 28, 2003 | 07:57 AM
Jeff C's Avatar
You dont happen to have a 33mm vtec valve laying around to even see if it fits into the relief, do ya?
Old Apr 28, 2003 | 10:50 AM
baonest1's Avatar
not right now. i just ordered the valve spring compr. tool. its coming in soon. i just got in touch with autoraceparts.com and he was pretty cool. i am going to get him the part # to the pistons and he is going to see what the deal is with them.
Old Apr 28, 2003 | 01:29 PM
2point6's Avatar
stupid question, but were the pistons put in back wards?
Old Apr 28, 2003 | 02:46 PM
baonest1's Avatar
Default Re: (2point6)
pistons are in correctly. i am going to go ahead and just get another set of pistons. this time the correct set. i am going to call JE and try to get a part # on the pistons.
Old May 6, 2003 | 05:12 PM
baonest1's Avatar
update: bob at ARI helped me out and i send one of my pistons to JE so they can check it out and confirm what kind of piston it is. this is after i spent couple days trying to find the part #. hopefully things work out
Old May 6, 2003 | 08:18 PM
1 2 NV's Avatar
im thinkin the other guys are right. obviously VTEC valve are bigger and the valves reliefs should almost go to the very outside of the piston like in C speeds picture. yours dont, as u can see. keep us updated i bet they arent VTEC pistons.
Old May 6, 2003 | 08:46 PM
baonest1's Avatar
Default Re: F*CK. wrong pistons=8bent intake valves. (hondaatwsu)
well bob @ ARI suggested i send them to JE just to be 100% sure that i wont get screwed again. we'll see what happens
Old May 7, 2003 | 09:44 AM
v-attack's Avatar
From: First in Flight, Type Rs of East Coast, NC, FL
well ur still homo, you should be listening to me and not some homo on phone
Old May 7, 2003 | 11:34 AM
baonest1's Avatar
Default Re: (v-attack)
so whatchoo got to say?? cut the pistons?? i am not gettin them cut.
Old May 7, 2003 | 02:47 PM
v-attack's Avatar
Well just because you said you are not getting them cut, I must conflict.......you should get them cut, or else, elcaminos will roll on dubs past house and harass homo neighbor joe with loud pipes
Old May 11, 2003 | 01:59 AM
EKFerioHawaii's Avatar
hahahaha...i like this post especially about caminos with dubs...hahahah...
That made my day...good night
Old May 11, 2003 | 03:39 PM
moto1320's Avatar
I have not used them yet, just asking...Are those the pistons JE makes just for the CRV-tec?
