00 Integra LS, cat-back or custom??
Old Apr 25, 2003 | 12:42 PM
HJ2kcivic's Avatar
Default 00 Integra LS, cat-back or custom??
In a couple months I will have a 00 teg ls A/T shoud I do Greddy 4-2-1 Header and Greddy sp cat-back or JDM ITR header and custom piping and muffler?? I want it to be N/A no boost!!
Old Apr 25, 2003 | 12:59 PM
white_rice83's Avatar
Default Re: 00 Integra LS, cat-back or custom?? (HJ2kcivic)
What kind of goals are you looking for? Where do you want your powerband located at?
You need to do some research on each of the parts you are considering and then decide for yourself if they are what you really want and are able to get you to that desired whp goal. Comprende?
Old Apr 25, 2003 | 01:45 PM
HJ2kcivic's Avatar
I want something that sounds good, not too lound or raspy and something that is going to give noticable gains throughout the poweband.
Old Apr 25, 2003 | 05:11 PM
mey_xanng's Avatar
Default Re: (HJ2kcivic)
I recommend the Greddy setup w/ a Carsound cat
the JDM ITR is all high end, and since you have an auto, the Greddy setup will suit your needs more
and the custom will be alot louder, inless a proper resonator is welded on
Old Apr 25, 2003 | 08:05 PM
DK4200's Avatar
Default Re: (mey_xanng)
i recommend a manual transmission!!!!
Old Apr 28, 2003 | 04:17 PM
non_VTEC's Avatar
Go for the Greddy. But if u decide on a custom make sure you get it madrel bent not crush bent.
Old Apr 28, 2003 | 08:16 PM
CoryTurner's Avatar
do not get the jdm type r header. way to big for an ls. and anways u'd be goin from 2.5" to 2.25" just wouldn't make since.......if u want something not loud pick up a type r exhaust. 2.25 inch and quiet. it's perfect for a sleeper if that's what ur looking for. u can save money when u get the type r exhaust that you can get a cat converter so you'll actually gain some power.
Bngo731
Oct 9, 2006 03:56 PM
daddymaxx
Nov 16, 2003 09:44 AM
BIGGIDYBOB
Mar 27, 2003 12:38 PM
mugenracer
Dec 3, 2002 04:13 PM
