Things to look for in a 96 LX
Maker sure the balance shaft seal retainer has been put on. Other than that there really isn't any major common problems. They're great cars...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Stew Pidasso »</TD></TR><TR><TD CLASS="quote">Maker sure the balance shaft seal retainer has been put on. Other than that there really isn't any major common problems. They're great cars...</TD></TR></TABLE>
I'm getting it from a dealership, so that probably won't be a problem. Thanks for the input.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by J B G Needs a Car »</TD></TR><TR><TD CLASS="quote">
Unfortunately, it still might be. It takes a real owner to follow thru on the "recall notice" to DO a repair. However, the is a way to find out...
I might be mistaken but I think you can go to the service department and have them run the VIN number to see if this recall has been done on this car.
</TD></TR></TABLE>Unfortunately, it still might be. It takes a real owner to follow thru on the "recall notice" to DO a repair. However, the is a way to find out...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RotaryBzzz »</TD></TR><TR><TD CLASS="quote">
I might be mistaken but I think you can go to the service department and have them run the VIN number to see if this recall has been done on this car.</TD></TR></TABLE>
Ok I will do that on Sunday when I go back down there.
how many miles? chances are that if the timing belt has been changed within the last year the recall has been done on it. the recall was done for me when I changed my timing belt at 91K
I have a 96 lx, and about the only things are the seal recall and the power window (passenger side) has problems. That seems to be common of all accords.
other than that, great car.
on 5th gen common things that break to look out for..
-power door lock actuator going bad and starts buzzing
-climate control **** breaking
-inner fender wall lining ripping out at high speeds
-door lamp lenses falling off
-power windor motor going out due to not lubricating the tracks
thats about everything that has gone bad to my car as well as others i know.. nothing really big.. anything else anyone
