what would win DEL SOL SI b16a or integra GSR?b18c?
since i have the weight advantage to you think i could beat a a gsr even tho he's got the torque advantage? were both pretty stock. thanks.
Whoever is the better driver. but even if you are the better driver, his car will give it to you in third though, might not be enough to overcome a good driver but...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sombasol »</TD></TR><TR><TD CLASS="quote">Del sol vtec = 2522 lbs
Integra GSR coupe = 2667 lbs</TD></TR></TABLE>
I'll nitpick the del Sol weight a tad - depends on the year and whether its got ABS. The 94 VTEC (B16a3) was 2490 lbs.
import_racer_7: No, you're wrong. Any stock del Sol has a weight advantage over a stock Integra. Period. But basically, its a driver race.
HTH!
Steve
HTH!
Steve
