did i do something wrong? [uneven drop]
Old Apr 25, 2003 | 09:23 AM
216.226.142.95:27016's Avatar
Default did i do something wrong? [uneven drop]
i installed H&R sport springs in my car last night and the driver side is noticebly lower than the passenger side. is there any way to fix this? what could i have done wrong in installation for this to happen?
Old Apr 25, 2003 | 09:27 AM
Malice's Avatar
New User
Default Re: did i do something wrong? [uneven drop] (216.226.142.95:27016)
blown shock?
Old Apr 25, 2003 | 09:28 AM
.Chris.'s Avatar
Default Re: did i do something wrong? [uneven drop] (MaliceGSR)
Check where the spring meets the car, there is a part there (forget what it is called) that is sometimes installed upside down.
Old Apr 25, 2003 | 10:57 AM
nope works just fine
Default Re: did i do something wrong? [uneven drop] (Black204GSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Black204GSR &raquo;</TD></TR><TR><TD CLASS="quote">Check where the spring meets the car, there is a part there (forget what it is called) that is sometimes installed upside down.</TD></TR></TABLE>
can anyone elaborate more on this?
Old Apr 25, 2003 | 12:42 PM
white_rice83's Avatar
I'm not familiar with H&R springs, but they might have different spring rates and drop heights in the front than in the back. Perhaps, you installed the front springs all on the driver side and the rear springs on the passanger side. That could explain why one side of the car is lower than the other.
Old Apr 25, 2003 | 01:07 PM
Jer'rome's Avatar
Default Re: did i do something wrong? [uneven drop] (white_rice83)
my friend dropped his accord wit h'&r's and his driver side is higher..the guy told him that cause driver's weight will compensate for the difference..same goes for RHD cars.... the right side is higher..well dats what he was told
Old Apr 25, 2003 | 09:10 PM
stumpyf4's Avatar
Default Re: did i do something wrong? [uneven drop] (JAH live1)
If it's a inch or less give it some time to settle, my Eibachs took a month to settle before the rear was level. If it's more than an inch than something is definitely wrong.
Old Apr 25, 2003 | 11:29 PM
Default Re: did i do something wrong? [uneven drop] (stumpyf4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stumpyf4 &raquo;</TD></TR><TR><TD CLASS="quote">If it's a inch or less give it some time to settle, my Eibachs took a month to settle before the rear was level. If it's more than an inch than something is definitely wrong.
wtf a month? my GCs take a 5 minute drive aroud the block to settle.
Old Apr 26, 2003 | 12:17 AM
jonoknut's Avatar
yea, id say it just needs to settle. . .if it gradually doesnt get better, then check out all the other options
jon
Old Apr 26, 2003 | 02:11 AM
IntEGNYC's Avatar
Default Re: did i do something wrong? [uneven drop] (jonoknut)
its natural for springs and shocks to settle and break in. My new suspension dropped about .75 inch 3 month later.
however, it should not be uneven from the get go. I'd bring it back to the shop and have it looked at. Improper installation can lead to larger problems down the road.
cheers
Old Apr 26, 2003 | 05:14 AM
B18PoweredCivic's Avatar
Make sure your spring is sitting flush on the shock...sometimes they are on their but not turned all the way to sit flush....
Old Apr 26, 2003 | 07:25 AM
the thing is. the driver side is lower than the passenger side. the passenger side is slightly higher and i feel is the right drop, the driver side is really close to being tucked. maybe i did install something wrong so i have to check it. the only diffuclty im having is those "this dot must face this direction with this hatch facing front/back etc. etc. can someone give me tips or directions on which way the dots must be or how the pieces must line up in a certain manner?
how about alignment, mine is a little off after the install, what could i have done to make this happen?
thanks
Old Apr 26, 2003 | 07:31 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by white_rice83 &raquo;</TD></TR><TR><TD CLASS="quote">Perhaps, you installed the front springs all on the driver side and the rear springs on the passanger side. That could explain why one side of the car is lower than the other.</TD></TR></TABLE>
i dont know about that but the h&r are 1.7" front 1.5" back with spring rates of 276 all around. the springs also has F or R ont he spring sexlaining which springs go where.
Old Apr 26, 2003 | 07:59 AM
cletus's Avatar
alignment will be needed.....you should always get it aligned after you lower a car because you just threw off all the factory suspension geometry. your camber probably isnt that bad but toe will kill your tires faster anyways. let your spring settle for a week and get it aligned.
Old Apr 26, 2003 | 10:12 AM
Default Re: did i do something wrong? [uneven drop] (cletus)
i can try aligning the toe myself but i was just wonder if its normal to need an alignment after a spring install. im not too worried about camber just the alignment where my steering wheel is affected.
Old Apr 26, 2003 | 09:20 PM
up
Old Apr 26, 2003 | 09:22 PM
P1mpSlap's Avatar
Welcome to the world of ******* H&R.
Your springs are FINE. The front is supposedly like 1.75F / 1.5 R or some ****. But it's supposed to have a more aggressive drop up front.
If you think that is bad???!!! Wait till it settles.
I have the H&R sports and after they settled, I tunk 1/2 inch on the front and there is no space on the rear.
I'll never buy H&R again.
Old Apr 26, 2003 | 09:27 PM
TheGSRGuy's Avatar
Default Re: (P1mpSlap)
IIRC each spring has a specific location...in other words there are 4 different springs.
The part that 'could be upside down' is the rubber piece called the bumpstop. I doubt that's the problem.
You're starting to see the results of aftermarket stuff...sometimes it just isn't good quality. Talk directly to H&R.
Old Apr 26, 2003 | 11:22 PM
Default Re: (TheGSRGuy)
one side has been lower than the other side since day one. does that mean the lower side is settled and the one that is a little bit higher has some settling to do?
Old Apr 27, 2003 | 03:24 AM
Mike G.'s Avatar
I had the same problem with my Integ. I always assumed it was caused by me not cutting the passenger side bump stops. It's either that or my fat ***.
If you find out the direct cause I'd be very interested to know the results.
Good luck
Old Apr 27, 2003 | 06:31 AM
P1mpSlap's Avatar
Default Re: did i do something wrong? [uneven drop] (Mike G.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mike G. &raquo;</TD></TR><TR><TD CLASS="quote">I had the same problem with my Integ. I always assumed it was caused by me not cutting the passenger side bump stops. It's either that or my fat ***.
Good luck </TD></TR></TABLE>
H&R Specifcally states: YOU DO NOT NEED to cut the OEM bumpstops unless you own the following cars......
Honda - Acura isn't one of them.
Old Apr 27, 2003 | 09:27 AM
Default Re: did i do something wrong? [uneven drop] (P1mpSlap)
so this uneveness is suppose to be like this or it will settle? should i deasseble and check if everything is the way its suppose to be?
Old Apr 28, 2003 | 09:05 PM
stumpyf4's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 216.226.142.95:27016 &raquo;</TD></TR><TR><TD CLASS="quote">i can try aligning the toe myself but i was just wonder if its normal to need an alignment after a spring install. im not too worried about camber just the alignment where my steering wheel is affected. </TD></TR></TABLE>
By lowering your car the point or angle at which the steering tie rod connects to the knuckle is effectively changed. On our integra when we lower the wheels toe out. So yes it is normal to need to align your car after a spring install, in fact should be done after performing any suspension work.
I'd give it a good month to settle, my Eibach's didn't even out until about 1 month later.
kasperxtcy
Suspension & Brakes
Sep 5, 2007 04:54 PM
janz3n
Mar 23, 2007 04:27 PM
spurge
Dec 5, 2005 09:20 AM
kevinm1981
Mar 28, 2004 07:33 AM
