91 crx si D16Z6 PG7 ECU and MSD RPM yada yada...
Old Apr 25, 2003 | 06:42 AM
KevronsEG's Avatar
Default 91 crx si D16Z6 PG7 ECU and MSD RPM yada yada...
will this work ok? and with the pg7 ecu it will have enough fuel for vtec? but will it be ritch downlow? Also should i set the vtec for 4800? Do i need anything else?
Old Apr 25, 2003 | 06:58 AM
USDM 4G VTEC's Avatar
Default Re: 91 crx si D16Z6 PG7 ECU and MSD RPM yada yada... (CIV616)
i have that setup right now
pulls good considering the conditions..
but always better to have a fual and vtec controler....
and is just s lil rich on normal driving
Old Apr 25, 2003 | 07:20 AM
KevronsEG's Avatar
Default Re: 91 crx si D16Z6 PG7 ECU and MSD RPM yada yada... (USDM 4G VTEC)
what do i do aboiut teh two prong thing in teh back of teh block? there is no sensor on teh d16z6?
Old Apr 25, 2003 | 08:06 AM
zCivic's Avatar
swap the 2 prong sensor from your orginal motor and place it in the Z6. You remove the bolt in the same area on the Z6 and screw the sensor into it. Or you can extend your harness to the thermo switch mounted in the top radiator hose of the engine. Where the thermostat goes.
Old Apr 25, 2003 | 01:08 PM
KevronsEG's Avatar
Default Re: 91 crx si D16Z6 PG7 ECU and MSD RPM yada yada... (zCivic)
what will happen if we dont use teh sensor at all?
Old Apr 25, 2003 | 01:31 PM
zCivic's Avatar
You cooling fan will not come on ever....So if you sit in traffic and notice your temp gauge starting to go up that would do it.....
hatchout01
Sep 25, 2015 06:45 PM
rasta420
21
Oct 30, 2004 07:10 AM
Blitzed
Jan 10, 2004 11:58 AM
max
Aug 7, 2001 09:00 PM
