Spark Plug Boot
Old Apr 24, 2003 | 08:37 PM
blah13's Avatar
Default Spark Plug Boot
Well I went to take out the plugs from my old d16a6 and the lil boot on the end is stuck in one of the shafts, the socket is obviously too big and needle nose dont reach it so how can I go about getting it out? Thanks!
Old Apr 24, 2003 | 10:10 PM
RCautoworks's Avatar
Default Re: Spark Plug Boot (blah13)
You mean the end that connects to the spark plug ? Is there any wire left from the spark plug wire ? Just wondering while I'm thinking of an idea for you.
Old Apr 25, 2003 | 03:30 AM
ThatRicerDaniel's Avatar
wow that sucks.. but if you go to orchard i know you can some needle nose that will get it.. i know this because i have a pair.
Old Apr 25, 2003 | 09:49 AM
blah13's Avatar
Default Re: Spark Plug Boot (NitrousDreamz)
Well when I pulled it the whole plastic shaft that covers the wire came out but the rubber "boot" on the end didnt, thats best way i can describe it. I have a punch thats bent at the tip and I was debating filing it to a point to see if I can jus push it through the side and pull it out but I dont want to scratch the inside. Really long needle nose would be perfect.
Old Apr 25, 2003 | 12:53 PM
I'm still alittle confused, sorry. So is it on the engine side or by the dizzy. If its the one inside the spark plug hole, maybe use a long screw driver.
Old Apr 25, 2003 | 08:51 PM
blah13's Avatar
Default Re: Spark Plug Boot (90blackcrx)
w00t! Got it out, jus took that punch I bent and managed to get it out. Ripped it pretty good but it'll still work.
LandHard
Jan 16, 2021 03:18 PM
David do
Mar 14, 2017 04:56 AM
xSOHC
Oct 15, 2013 12:08 PM
emwavey
Jun 25, 2003 11:20 AM
