does this sound right?
I found this web site about a ZC swap in a crx si and that it would be a complete bolt in and i could use the stock tranny and ecu. on there it also says that you could use a greddy eg turbo kit.
http://www.angelfire.com/ok4/CRX/garycrx.html
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sethm »</TD></TR><TR><TD CLASS="quote">I found this web site about a ZC swap in a crx si and that it would be a complete bolt in and i could use the stock tranny and ecu. on there it also says that you could use a greddy eg turbo kit.
The cr-x si tranny is a good tranny to use.....you can also use the stock si computer but the 88-89 teg ecu works best....And yes you can use your eg turbo kit on the zc motor as long as it is d-series it can pretty much be interchanged with any other d-series
