4th gen turbo
Old Apr 24, 2003 | 07:44 PM
Max_lude's Avatar
Default 4th gen turbo
where did you put the piping for a FMIC on the driver's side?
Old Apr 24, 2003 | 08:05 PM
Max_lude's Avatar
Default Re: 4th gen turbo (Max_lude)
id like to know what is your vafc settings as well!
thanx
Old Apr 25, 2003 | 04:20 AM
spoolinlude's Avatar
I live under a rock
Hey i know i look like a newbie, but my roommate managed to get my other name banned from here so here it goes.
depending on what FMIC you have, will depend on the piping you need, if its most FMIC's on preludes you should be able to get pipes from whoever you bought the kit from, if its a custom setup (no kit) then try going to revhard, their pipes work with the spearco FMIC as well as the revhard one that comes in the kit, i like these....... your vafc settings will depend on how much boost you run.... the more fuel you'll need to add per more boost......if you're only at 6psi, usually 10% correction works good
Old Apr 25, 2003 | 07:08 AM
Max_lude's Avatar
Default Re: 4th gen turbo (spoolinlude)
i wanna know where you pass the piping of the FMIC from the front of the car to the engine bay on the drivers side?
cause i dont see how it can go there.
thanx
Old Apr 25, 2003 | 08:14 AM
hksturbolude's Avatar
it can get around there...its VERY tight though...my IC piping is about a quarter inch away from my radiator maybe less...but it can get around the drivers side, there should be room right next to the bottom drivers side of the radiator
Old Apr 25, 2003 | 01:07 PM
Max_lude's Avatar
Default Re: 4th gen turbo (hksturbolude)
thanx
how about your vafc hack settings with 450 cc injectors on 4th gen vtec?
Old Apr 25, 2003 | 02:05 PM
I live under a rock
the rev hard pipes fit nice, really tight fit with AC, but with some finess you can get it to line up.... leave the front end off for doing this obviously, i wrapped mine in exhaustt tape...(cloth is ok too) to install them so i wouldn't scratch them, then cut it off when they were in... worked nice... good luck
Old Apr 25, 2003 | 03:51 PM
Max_lude's Avatar
anydody knows what are the settings for the afc hack on a 4th gen vtec?
IIVIIoOkY
Nov 10, 2006 08:46 PM
kholmes
Dec 24, 2004 09:15 AM
TurboSam
May 6, 2004 06:55 AM
boostedbar
16
Jul 4, 2003 06:32 PM
imonkie
Nov 22, 2002 10:07 AM
