99 JDM ITR cluster plug n play in 2001 GSR?
Old Apr 24, 2003 | 07:23 PM
threatcon13's Avatar
New User
Default 99 JDM ITR cluster plug n play in 2001 GSR?
I searched on the topic but couldn't get a confirmation that this would be plug n play on 2000/2001 spec. If anyone has actually DONE this on their 2000/2001 or knows for a fact what it takes to be done, please let me know. Thank you.
Old Apr 24, 2003 | 07:25 PM
Dave-ROR's Avatar
Default Re: 99 JDM ITR cluster plug n play in 2001 GSR? (Threatcon13)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Threatcon13 &raquo;</TD></TR><TR><TD CLASS="quote">I searched on the topic but couldn't get a confirmation that this would be plug n play on 2000/2001 spec. If anyone has actually DONE this on their 2000/2001 or knows for a fact what it takes to be done, please let me know. Thank you. </TD></TR></TABLE>
plug it in
does it all work? if yes, good job, if no, post here and i'll waste my time searching for the threads I've posted the solution to 20+ times probably.
Old Apr 24, 2003 | 07:47 PM
Mires's Avatar
All you have to do is take out your cluster. Then unscrew all the screws on the back of the both the clusters. After that switch the back halfs of the clusters. Put all the screws back in the clusters and plug the jdm one in your car. Taking the back off the cluster was the hardest for me because I couldnt get the tabs pressed down to pull it off. Just make sure you keep them somewhat level upside down so the actuall gauges stay in place because you have to remember they are just sitting there and are not screwed down.
Hope you get them working because I love mine
Old Apr 24, 2003 | 07:50 PM
Dave-ROR's Avatar
Default Re: 99 JDM ITR cluster plug n play in 2001 GSR? (ITR-862)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITR-862 &raquo;</TD></TR><TR><TD CLASS="quote">All you have to do is take out your cluster. Then unscrew all the screws on the back of the both the clusters. After that switch the back halfs of the clusters. Put all the screws back in the clusters and plug the jdm one in your car. Taking the back off the cluster was the hardest for me because I couldnt get the tabs pressed down to pull it off. Just make sure you keep them somewhat level upside down so the actuall gauges stay in place because you have to remember they are just sitting there and are not screwed down.
Hope you get them working because I love mine </TD></TR></TABLE>
just remove the 3 screws that hold the bezel/cover to the rear housing first. the tabs can be easily opened/pressed down/etc with multiple screwdrivers (two works, once two of the tabs are held down it comes off easy).
then remove the screws for the gauges.
Old Apr 24, 2003 | 08:08 PM
Mires's Avatar
Default Re: 99 JDM ITR cluster plug n play in 2001 GSR? (dawhiteboy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dawhiteboy &raquo;</TD></TR><TR><TD CLASS="quote">
then remove the screws for the gauges.</TD></TR></TABLE>
Either way you still have to take out all the screws because the gauges are attached to the back housing. I wedged a flat head screw driver (carefully of course) between the two parts and then pressed down a couple of tabs with my hand and rotated the screw driver at the same time and they came apart easily.
Old Apr 24, 2003 | 08:17 PM
New User
Hope you get them working because I love mine </TD></TR></TABLE> Thank you.this sounds like a good solution/approach. I will attempt it this weekend.
Old Apr 24, 2003 | 08:18 PM
B00ST2nR's Avatar
Nice sig.
Modified by Skunk2nR at 9:31 PM 4/24/2003
Old Apr 24, 2003 | 08:38 PM
New User
Default Re: 99 JDM ITR cluster plug n play in 2001 GSR? (Skunk2nR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Skunk2nR &raquo;</TD></TR><TR><TD CLASS="quote">Nice sig.
Modified by Skunk2nR at 9:31 PM 4/24/2003</TD></TR></TABLE> thanks chris sartor #2
Old Apr 24, 2003 | 08:44 PM
B00ST2nR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Threatcon13 &raquo;</TD></TR><TR><TD CLASS="quote"> thanks chris sartor #2 </TD></TR></TABLE>
whatever
ek_Tart
Mar 17, 2007 08:42 AM
IntegraDriver
Mar 12, 2007 03:58 PM
allmotorEG-SI
Jun 8, 2004 04:57 PM
Nextelbuddy
Apr 21, 2004 10:11 AM
romeirome1
Mar 5, 2003 07:58 PM
