Peoples with h22a swap!
yo yo, what up guys. im on the brink of finishing my h22a swap into my 95 civic coupe, and i ran into a problem while hooking up the fuel line that comes off the fuel filter and goes into the fuel rail.....well its too short. how did you guys go about doing this???
Get a 24" fuel line, cut it down to the size needed (mine ended up being around 21") and run the fuel line either underneath (cleaner IMO) or above the intake manifold to the other end of the fuel rail. Either that or get an Accord fuel rail, since the inlet is on the same side as a Civic rail.
you will need a 90-93 Accord fuel rail if you want it to look like this..
If you dont want to get the rail then its cut and extend the fuel line to the other side of the fuel rail.
