K24-R tuned Civic Si
For those of you who want to know what an increase in displacement might do read on.
We took a RSX-S engine, installed type R cams, cai, intake gasket and catback and tuned it. After that we took a K24 Accord bottom end and swapped it in in place of the K20A2 block.
With the increase in engine capacity, breathing needs to be improved. This is seen in the torque drop after 6000 rpm The next step to improve top end of the K24 would be to try an ITR intake manifold and headers.
Modified by Hondata at 7:28 PM 4/24/2003
Cool! Great info...
Hey, lets see Hondata work on this stuff for the k20a3 -- I know alot of EP owners that want to keep the engine but swap the head and maybe do cams/etc.... can this stuff be done?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The End »</TD></TR><TR><TD CLASS="quote">Somebody is going to be pissed.
? why
? why
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Team »</TD></TR><TR><TD CLASS="quote">
? why</TD></TR></TABLE>
You will know soon.
You will know soon.
You will know soon.</TD></TR></TABLE>
Care to elaborate
Care to elaborate
is the k24 bottom end using the accord 9.8:1 compression pistons from the accord bottom end?
I imagine putting the a2 pistons in would help get the torque figure closer to the 190ft-lb range and also help with higher rpm power (along with the breathing enhancements you mentioned).
what's the difference in bowl volume between the a3 and a2 heads? as in is there any change in compression due to swapping heads?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redronin22 »</TD></TR><TR><TD CLASS="quote">LOLZ @ people who did the A2 swap. Should have waited. It is true, the best things come to those who wait. lolz</TD></TR></TABLE>
TSX?
TSX?
What about the K24 in the Accord, Element and CRV?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WR93EG »</TD></TR><TR><TD CLASS="quote">TSX is K24A2</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by flu1512 »</TD></TR><TR><TD CLASS="quote">Question...
Are the K24's in the Accord, Element, TSX, & CR-V all the same model?
Or are there various K24's?
Just like in the K20, ex K20a, K20a2, K20a3.</TD></TR></TABLE>
someone answer this..r the blocks all the same or not??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FrostyDC4 »</TD></TR><TR><TD CLASS="quote">What about the K24 in the Accord, Element and CRV?
