Mechanical or electrical oil pressure gauge?
Old Jun 30, 2001 | 10:02 AM
Ibuprofen's Avatar
Default Mechanical or electrical oil pressure gauge?
which would be easier to install? i'm lazy..
Old Jun 30, 2001 | 10:19 AM
travis's Avatar
Default Re: Mechanical or electrical oil pressure gauge? (ITyp3R)
electrical, IMHO, is the way of the lazy
Old Jun 30, 2001 | 10:34 AM
Mike M's Avatar
Founding Member
Default Re: Mechanical or electrical oil pressure gauge? (ITR#231)
Electrical
Old Jun 30, 2001 | 10:52 AM
KJ's Avatar
KJ
Default Re: Mechanical or electrical oil pressure gauge? (TypeRmsm)
If you get a mechanical one and something goes wrong with it...you'll have hot oil ALL over your car and body. NOT GOOD! Go with Electrical Guages for things that involve fluids (that must be run into the car).
Old Jun 30, 2001 | 11:38 AM
Kamil's Avatar
Default Re: Mechanical or electrical oil pressure gauge? (KJ)
u can get a pressure isolator. (autometer has them) viola, no more hot oil showers.
from my experiance they're equal in install time... you're either running a tube or a wire.
The mechanical is DEFINETLY more accurate and quicker responding... and is the proper way of doing it.
BTW, why do you need an oil pressure gauge?
I had one on my teg and only time it told me that the pressure was different from normal was when the gauge started leaking.
I would get an oil temp gauge instead... see above on weather u should get a mech or elect.
[Modified by Kamil, 3:39 PM 6/30/2001]
Old Jun 30, 2001 | 12:23 PM
SwiftTypeR's Avatar
New User
Default Re: Mechanical or electrical oil pressure gauge? (Kamil)
SHOW ME PIX OF THAT GURL!!!
Old Jun 30, 2001 | 01:07 PM
hondura's Avatar
That is almost like saying that if you get an electrical one and something goes wrong with it... it'll spark and start a FIRE under your dash.
If the gauges wether they be electrical or mechanical if installed correctly will work. It just depends on your situation. All I can say is get good gauges, cheap electrical gauges can be damaged with a hard shock or short out, cheap mechanical gauges can leak or pop if pressure is higher than gauge can take.
Old Jun 30, 2001 | 05:02 PM
Ibuprofen's Avatar
correct me if i'm wrong, but the oil pressure guage monitors if your engine is getting sufficent oil right?
BrOkEn_Dc2
Apr 15, 2006 11:09 PM
soon2b
May 2, 2005 09:47 AM
Petah
Apr 24, 2002 12:31 PM
IGGY
Nov 28, 2001 02:14 AM
