obd2 b20vtec into 91crx si?
ive searched for info on this topic but havent found much.
what all would i need to put my b20vtec from my obd2 ls integra into the 91 crx si?
can i get a hydro clutch mastercylinder and pedal assembly and make my hydro tranny work?
go to hasport.com and get a cable to hydro conversion if you want to use your new tranny. About the wiring, easiest is to run the motor non-obd...use pr3 ecu, 91 teg injectors and distributor...assuming you already converted from dpfi to mpfi.
cheyennerex
Mar 15, 2003 07:15 PM
i am wallies type r
Nov 16, 2001 12:09 PM
