Speedo prob...help???
hey,
about a week a ago i was driving and the whole right side of my gauge cluster stopped working (speedo, odometer, trip meter) the gauge cluster isnt the problem, and the fuses seem to be cool...help????
Did you check your speedo cable if it's hooked up? Maybe you just need to replace the cable. Pull out your cluster then run your car a few feet and see if the cable is turning.
i wasnt sure how to check the cable...a homie said there was a chance that the cable was broken...so that little spindle inside the line will spin if its connected and workin properly?? thanx for the help...
peanut butter
Feb 18, 2008 04:00 PM
SHJR89CR-X
Feb 23, 2006 06:49 PM
rasta420
Aug 26, 2002 04:25 PM
