Check Engine Light (Code 16)?? 89 Accord Lxi Auto 4dr
Hey guys how is it goin. A friend of mine has an 89 Accord lxi and he is having some problems with his car. i already searched and found some good info regarding check engine lights and i found a link to cross refrence codes in someones post in the archives http://tech.hybridgarage.com/tech/codes.html . the code is one long blink and the six short ones. is the first blink just the ecu turning on or does it represent the 10's. the cross reference sheet says a code 16 is for _fuel injector system_ but it only says its for an accord 90-95??????????? I just dont understand? can someone please help me out. i guess the car has a hard time starting sometimes, sometimes it fires up and sometimes it just cranks. sometimes i smell gas when it is starting/running. any help would be great. thanks in advance. J
The code should keep repeating. I suspect it's a code 6. The TW sensor (engine coolant temp) can throw a code if the antifreeze is low.
