H22a need help with shift linkages pls pls pls!!!!!
i need help on where to locate the linkages in my 93 del sol
if any body has done this swap pls let me know the
linkage set up pls pls pls
Done it a few times, but i recommend taking it to a shop so you dont mess things up. It requires cutting and drilling in the inside of your car.
Also you still use the hydrolic trans, AJ meant that you have to use the cables from the H22A, not the metal bar linkage like in the B series. Plus all H22A trans are hydrolic.
