gsr oil consumption
Old Apr 24, 2003 | 08:24 AM
b18cvtec's Avatar
Default gsr oil consumption
i have a 94 gsr pretty much stock except for the stage 3 clutch and aem cold air intake. i've notice the lately alot of oil consumption? nothing is leaking and my car isn't smoking until i hit vtec? i believe that it may be a slight possibility that the head gasket may be leaking from internally. i've whipped the exhaust sut, but it doesn't smell like oil. thanks for the help everyone.
Old Apr 24, 2003 | 08:35 AM
Seann's Avatar
Default Re: gsr oil consumption (b18cvtec)
Try switching to regular motor oil if you are using synthetic. I had this problem and switched back to Castrol GTX and put in some Rislone Ring Sealer at my last oil change and it hasn't hardly burned a drop.
Good luck
Old Apr 24, 2003 | 08:46 AM
B U N M A N G O's Avatar
do a compression test and a leakdown test, that will tell you where you're having the problem. as mentioned before, try switching to conventional and see if that helps. you might want to try a search on this too and read up on other guys who had this problem.
Old Apr 24, 2003 | 08:49 AM
VTECorona's Avatar
Default Re: gsr oil consumption (bunmango)
Mine was doing that too when I was running mobil-1 syn. I heard most gs-r do burn some oil but if you're going through alot of it then I would have it checked out. Do you go into vtec alot? If so that could be 1 reason
Old Apr 24, 2003 | 09:36 AM
PsychO's Avatar
Default Re: gsr oil consumption (97RedTegGSR)
My friends gs-r was burning oil like crazy, as much as a quarte every 2-3 weeks. He took it to Acura and they couldnt figure out what was wrong, replaced piston rings, yadda yadda and it still burned oil. So they gave him a new motor for free.
^_^
PsychO
Old Apr 24, 2003 | 10:32 AM
Cone's Avatar
Default Re: gsr oil consumption (PsychO)
valve guides or vavle seals leak a lot too, not just the rings to Acura for not replacing those...maybe they were lazy. I burned oil when I was using full synthetic, now I run high milage oil and it seems to be fine thus far.
-Andrew
Old Apr 24, 2003 | 11:40 AM
Muckman's Avatar
Moderator in Chief
Default Re: gsr oil consumption (Stealth 95 GS-R)
I fall into this category too now. '00 GSR w/ 62k miles, daily beaten. Started burning oil where it never did before. Always used Mobile 1 sythentic. Blah.
Old Apr 24, 2003 | 01:05 PM
DSayavan's Avatar
Default Re: gsr oil consumption (Muckman)
When was the last time you changed your PCV valve?
Old Apr 24, 2003 | 01:44 PM
mickey513's Avatar
I have a 94gsr and I don't add a single drop of oil in between oil changes (every 3000 miles).
BUT I did burn oil on two occassions, when I used synthetic oil once, had to add almost a whole qt. in between oil change No thanks for me, went back to regular convetional oil. My other time was when I drove 4 hours each way on a trip. I recently switched to the high mileage oil my last two oil change and it's still fine, no problems yet.
Old Apr 24, 2003 | 01:50 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Muckman &raquo;</TD></TR><TR><TD CLASS="quote"> I fall into this category too now. '00 GSR w/ 62k miles, daily beaten. Started burning oil where it never did before. Always used Mobile 1 sythentic. Blah.</TD></TR></TABLE>
same here, '97 GSR, 106k miles now, had problems since around 70k. Used Mobil 1 10w30 and 5w30 after break-in, up until 90k miles or so when I switched back to conventional 10w30... still burned oil, switched to 20w50. Still burning 1qt every ~800mi. Compression test = , 185, 180, 160, 155, or something like that.
Old Apr 24, 2003 | 02:26 PM
Integraholic's Avatar
Default Re: gsr oil consumption (Seann)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Seann &raquo;</TD></TR><TR><TD CLASS="quote">Try switching to regular motor oil if you are using synthetic. I had this problem and switched back to Castrol GTX and put in some Rislone Ring Sealer at my last oil change and it hasn't hardly burned a drop.
Good luck</TD></TR></TABLE>
Why in the hell would you go from synthetic back to regular? That's a no no.
Old Apr 24, 2003 | 03:29 PM
strider7slvr2k1gsr's Avatar
Default Re: gsr oil consumption (Integraholic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Integraholic &raquo;</TD></TR><TR><TD CLASS="quote">
Why in the hell would you go from synthetic back to regular? That's a no no.</TD></TR></TABLE>
Because, the molecules in synthetic oils are much more uniform (and smaller I believe) ... while the molecules in dino oils are of varying sizes. Some of the larger molecules in dino oils 'plug up', if you will, the passages that the smaller molecules could leak out through.
Haven't you ever heard of folks switching from dino oils to synthetics, and then having problems with oil leaking? It seems that this has been discussed many times on the different Honda/Acura boards that I frequent. Maybe you just never heard about it.
I'm sure someone else who has more technical insight into it can elaborate.
Old Apr 24, 2003 | 04:55 PM
Muckman's Avatar
Moderator in Chief
Default Re: gsr oil consumption (DSayavan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DSayavan &raquo;</TD></TR><TR><TD CLASS="quote">When was the last time you changed your PCV valve?</TD></TR></TABLE>
Uhh never. Maybe I should?
Old Apr 24, 2003 | 05:09 PM
TheGSRGuy's Avatar
VTEC engines are known to burn about 1/2 quart every 3000 miles.
Old Apr 24, 2003 | 05:37 PM
koco's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18cvtec &raquo;</TD></TR><TR><TD CLASS="quote">i have a 94 gsr pretty much stock except for the stage 3 clutch and aem cold air intake. i've notice the lately alot of oil consumption? nothing is leaking and my car isn't smoking until i hit vtec? i believe that it may be a slight possibility that the head gasket may be leaking from internally. i've whipped the exhaust sut, but it doesn't smell like oil. thanks for the help everyone. </TD></TR></TABLE>
Run your fingertip inside the tailpipe and see if it's oily. A normal running motor should have a dry black residue in the pipe. If it's hard to get off your skin and greasy, you know where your oil is going. Compare the exhaust pipe deposits to that of a known good car and you'll see what I mean.
Old Apr 25, 2003 | 08:20 PM
TheGSRGuy's Avatar
Default Re: gsr oil consumption (koco)
Oil in the exhaust system will also destroy a cat converter.
Old Apr 26, 2003 | 01:13 AM
slimbo's Avatar
Default Re: gsr oil consumption (TheGSRGuy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheGSRGuy &raquo;</TD></TR><TR><TD CLASS="quote">Oil in the exhaust system will also destroy a cat converter.</TD></TR></TABLE>
oh yeah... i can vouch for that personally
i overfilled it at the track one time...
it took me a good hour of washing to get the stains off my rear bumper.
Old Apr 26, 2003 | 08:20 AM
jabroni95gsr's Avatar
Default Re: gsr oil consumption (slimbo)
Integras just burn a little oil in vtec...so if you constantly drive in vtec and beat on it, you will go through a qt or even 2 in 3000 miles....i have this condition with outstanding compresion at 99k. 230,235,240,235
theslugbug
May 10, 2008 04:35 AM
duneracer69
Oct 8, 2007 04:29 PM
streetlights
Jun 23, 2007 06:37 PM
vtec8804
May 31, 2007 09:24 AM
joshalee
Jan 20, 2005 04:35 PM
