Type R LMA for Type R cams
Old Apr 24, 2003 | 07:36 AM
95 integra's Avatar
Default Type R LMA for Type R cams
So will I need the Type R lost motion assemblies to run the type R cams? Ive heard that with the bigger cams that the stock gsr LMAs dont have enough movement and bottom out, causing the cams to be put in a bind and specifically breaking.
Old Apr 24, 2003 | 09:16 AM
OBDI JEDI's Avatar
Default Re: Type R LMA for Type R cams (95 integra)
never had a problem like that, and ive been running ITR cams for 2 years now.
Old Apr 24, 2003 | 10:33 AM
obd2gsr's Avatar
Default Re: Type R LMA for Type R cams (OBDI JEDI)
haven't had a problem either. running itr cams for 2 years, too
Old Apr 24, 2003 | 10:36 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
GS-R's and ITR's use the same lost motion assemblies.
Old Apr 24, 2003 | 11:44 AM
Mr. Softee's Avatar
Default Re: Type R LMA for Type R cams (PatrickGSR94)
no they dont.
but, you do not need itr lmas. not until you use C's or sk2 IIIs
Old Apr 24, 2003 | 12:11 PM
95 integra's Avatar
Default Re: Type R LMA for Type R cams (94goldjungsr)
Here's another question...Does the B16A and the ITR use the same LMAs?
Old Apr 24, 2003 | 12:15 PM
Newman's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95 integra &raquo;</TD></TR><TR><TD CLASS="quote">Here's another question...Does the B16A and the ITR use the same LMAs?</TD></TR></TABLE>
Nope, ITR is it's own LCAs, and allow for more clearance. You normally don't need to upgrade the LCAs unless A) you have an old B16 head and plan to rev it high with Type R cams or B) you run aftermarket cams with an even higher lift & duration, which can ultimately cause your stock LCAs to collapse and fail, and putting the stress on your cams and causing them to break.
Old Apr 24, 2003 | 01:21 PM
95 integra's Avatar
Default Re: Type R LMA for Type R cams (Newman)
Alright thanks. I'll be sticking to the stock gsr's unless I decide that those are worn out, which they might be with 150k on them. BTW, worn LMAs can cause excessive valvetrain noise
Old Apr 24, 2003 | 03:23 PM
Community Builder
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94goldjungsr &raquo;</TD></TR><TR><TD CLASS="quote">no they dont.
but, you do not need itr lmas. not until you use C's or sk2 IIIs</TD></TR></TABLE>
damn, Carland Acura's site is wrong then.
So how does one go about replacing lost motion assemblies? And somebody please explain exactly what they do because I'm not real clear on that. I know my friend's SOHC VTEC valvetrain has the LMA's above the cam instead of below the cams like our cars.
Old Apr 24, 2003 | 04:55 PM
95 integra's Avatar
Carland acura has the same part #s for both gsr's and type Rs on almost everything, including pistons, rods, etc. LMAs keep your VTEC rocker arm from flopping around like a loose dick when vtec isnt engaged. I believe that one you take the rocker arms out that they should just fall out. BTW, on your friends civic it probably doesnt have enough room to have the LMAs below the rockers like ours.
Old Apr 24, 2003 | 05:14 PM
tilt's Avatar
finally found it in my bookmarks... looks like you have to remove the rocker assembly as mentioned.
http://www.lightningmotorsport...I.htm
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 &raquo;</TD></TR><TR><TD CLASS="quote">
So how does one go about replacing lost motion assemblies? </TD></TR></TABLE>
Old Apr 24, 2003 | 07:35 PM
Community Builder
Default Re: Type R LMA for Type R cams (tilt)
wow that's a great link, into the bookmarks with it!
Old Apr 24, 2003 | 07:56 PM
dLo GSR-stolen-now-WRX's Avatar
From: kyoto sangyo daigaku, kyoto, japan, sometimes bay area CA
You don't need them.
Old Apr 25, 2003 | 04:40 AM
Xsi's Avatar
Xsi
Default Re: Type R LMA for Type R cams (dLo GSR)
I've been running CTR's for a year or so on a stock valvetrain with no problems, I'm yet to come across anyone on ht that has broken R cams just because of the LMA's
jdm_boy.1
Aug 22, 2009 08:48 AM
chicken18
Mar 24, 2009 12:32 PM
slowazzteg
Dec 25, 2005 06:51 PM
rpm9100
May 1, 2003 04:28 PM
