changing drive belts...
Old Apr 24, 2003 | 07:11 AM
dip-set's Avatar
Default changing drive belts...
is there a specific order in changing them...is there any site with a DIY step by step procedure with pics...im wondering if by changing my drive belts i will get rid of some of the squeeks and squeels from the pulleys...(power steering belt whines with the rpm)(alternator belt makes this slight thumping sound at idle like its not rotating smoothly) figure changing the belts and cleaning up the pulleys will give me a lil smoother feel....comments,tips,advice,flames,whatever, is all appreciated....thanks..
Old Apr 24, 2003 | 08:07 AM
IN VTEC's Avatar
Default Re: changing drive belts... (teg-your-it)
You have to remove them from outside-in.
Power strg, then AC, then alternator.
For the AC belt, you can just cut the belt to remove it, but you'll still need to remove the lower engine mount to put the new one back on.
Tension them properly.
Old Apr 24, 2003 | 09:13 AM
dip-set's Avatar
Default Re: changing drive belts... (IN VTEC)
thanks for the reply...i"ll have a shop do it..i dont wanna **** with it...i get frustrated to easily when working on my car and **** never goes easy for me then i tend to take it out on the car...my last beater really got a beatin when i was working on it(i forget what i was doing at the time) but it didnt wanna start so i took a hammer to the car..beat the **** outta the body...i dont wanna beat up the teg so i"ll leave it alone...even though it still frustrates me hearing the belts whining...
rock...........me...........hardspot
u get the point...
single_slam
Feb 23, 2014 05:40 PM
sneekz206
Jan 4, 2011 03:30 PM
NZDelsoldude
Nov 29, 2004 12:56 PM
andrewasf77
Jul 8, 2003 12:14 PM
shadowdawn
Jun 3, 2002 10:24 PM
