*NEED Injector HELP*
Old Apr 24, 2003 | 04:47 AM
Slimer89's Avatar
Default *NEED Injector HELP*
My injectors are stuck open and are drowning my cylinders with fuel. The car will not start. How can i go about fixing this??? Any help is good, thanks.
Old Apr 24, 2003 | 06:13 AM
Stew Pidasso's Avatar
Default Re: *NEED Injector HELP* (Slimer89)
Are they wired up correctly? I wouldn't crank it if they're stuck open. If enough fuel is pumped in there it could hydrolock your engine...
Old Apr 24, 2003 | 08:46 AM
Slimer89's Avatar
Default Re: *NEED Injector HELP* (Stew Pidasso)
Yeah, i'm not to sure what exactly happened. I was slowing down as i was getting off of the highway when my car just kind of bogged down and shut off. Any suggestions of to what may have caused this? As far as things being wired up correctly, i have had the swap in since August with no problems. This was kind of out of the blue.
Old Apr 24, 2003 | 09:06 AM
accordhybrid's Avatar
More than likely you should send them out to have them checked and cleaned, you can try rceng.com or cruzinperformance.com they both do injector cleaning.
Accordhybrid
Old Apr 29, 2003 | 07:02 AM
Slimer89's Avatar
Default Re: *NEED Injector HELP* (accordhybrid)
Anyone else have some suggestions to what may be the cause of the problem?
Old Apr 29, 2003 | 08:31 AM
Kataku2K3's Avatar
It's either improper wiring or the injector is stuck... If you've been driving it sense August with NO problems then that isn't the case unless something shorted... Continuity test your injector grounds (the wires that run to your ECU, brown, red, blue, yellow) over the chassis... If you have continuity then something is wrong... Most likely a short... Are you running high fuel pressure?? This can sometimes cause them to stick... Good Luck and let me know if you find anything else...
Old Apr 30, 2003 | 06:43 AM
Slimer89's Avatar
Default Re: *NEED Injector HELP* (Kataku2K3)
I will do a fuel pressure and continuity test today and let you know what I come up with. Thanks for the suggestions.
Old May 1, 2003 | 06:34 AM
Slimer89's Avatar
Ok, so i got a fuel pressure gauge and checked my fuel pressure. It has been all over the place, starting off at 60 psi, dropping to 28, then to 0 for a while, and then up to 100psi!!! I know it is not the regulator because i pressure tested that, and it held. Still have to check for a short in the injector wires.
Old May 1, 2003 | 08:24 AM
Kataku2K3's Avatar
Is that with your motor running or just your pump powered up??? Let me know how it goes... Good Luck
Old May 1, 2003 | 10:06 AM
Slimer89's Avatar
That is with the motor running. The problem is, it barely runs (idling at 500rpm's), and if you give it gas, it stalls out.
NewEvolutionIX
Aug 28, 2012 05:39 AM
quik1
Nov 6, 2005 10:03 AM
game over
12
Apr 22, 2005 05:05 AM
krazywhitboy
10
Oct 7, 2004 10:16 AM
