Will 94-97 Accord shocks fit on 97+ Prelude ...Alot more to this READ ON
Old Apr 23, 2003 | 11:38 PM
Showoff's Avatar
Default Will 94-97 Accord shocks fit on 97+ Prelude ...Alot more to this READ ON
I'am going to be doing a 4 lug to 5 lug conversion and if i do go about this , can i use my 1995 accord shocks on the 1997 and up preludes ? i going to be Getting the whole entire front end and back so i will have all Prelude Suspension
By the way its going to be coming of an Type SH prelude 1998
Thank's
Old Apr 24, 2003 | 05:40 AM
TurboLude97's Avatar
Default Re: Will 94-97 Accord shocks fit on 97+ Prelude ...Alot more to this READ ON (Showoff)
the struts wont fit. the bracket on the bottem of the struts for the 97+ preludes is bigger than the one for the accords. and im not exactly sure about using a type SH suspension. I heard its different than the base model but im not sure what the differences are. The ATTS from the SH is why the suspension is different.
Could someone with an SH help him out?
Old Apr 24, 2003 | 06:33 AM
Honda318dx's Avatar
Default Re: Will 94-97 Accord shocks fit on 97+ Prelude ...Alot more to this READ ON (TurboLude97)
I think the fronts are the same, the rear it totally opposite!! You can just swap hubs in the rear, no reason to do the whole rear suspension...
Oh yea, if your getting SH prelude knuckles for the front of the accord, you will also need..
Prelude VTEC calipers
prelude Lower control arms
Prelude Radius rods, shimmed to the correct length
Prelude tie rod ends, swapped to opposite sides
Prelude Axles, and halfshaft
Good luck..
Old Apr 24, 2003 | 08:42 AM
Nick M's Avatar
Default Re: Will 94-97 Accord shocks fit on 97+ Prelude ...Alot more to this READ ON (Honda318dx)
why?
Old Apr 25, 2003 | 12:13 PM
Showoff's Avatar
Default Re: Will 94-97 Accord shocks fit on 97+ Prelude ...Alot more to this READ ON (Nick M)
The reson is i'am planign to get Brembo 13" Brake it and i rather be safe have 5 lugs i will be going T-60 Turbo just feel safer , well what other opsions do i have on making my 1995 accord to 5 Lugs ? the 98+ V6 accords Maybe or should i get 'em off an 97+ Prelude and not Type SH ? Thanx for the help What else can i do Brake wise ?
mugenmarauder
Feb 27, 2006 12:22 PM
duceducecord
Feb 14, 2006 11:00 AM
duceducecord
Feb 13, 2006 11:40 AM
boiwitwhitehond
Jun 26, 2005 08:04 AM
billk2k
Mar 31, 2003 01:08 PM
