Need help figuring out temp gauge wiring!!
I need some help getting my temp gauge to work, I have a 91 LS block with a 95 LS head and all the wiring is from the 95, it's in a 94 EG CX. I thought I'd ask you guys since you guys own Integras and know them front to back. I want to know where is the Temp gauge on the 91 block? Where its at on the 95 block? Whats the wire that gets hooked up to it on the 95 wiring? Does the same wire that turns on the radiator fans also work your gauge? My fan wire is right by the thermostat but since the block is a 91 there isn't anywhere to connect it there
Any help is apreciated
I don't want to overheat my car. Thanks!
daniel99em1
Jan 14, 2019 06:34 PM
EquipedWithVtec
Oct 10, 2008 08:57 PM
