how do i wire up a 4 wire o2 to a p28 ecu
Old Apr 23, 2003 | 06:15 PM
roc's Avatar
roc
Default how do i wire up a 4 wire o2 to a p28 ecu
just finished my b16a2 swap into my 95 cx.i wired up vtec and everything else to go with it.my only problem is wiring up the 4 wire o2 to the ecu.or can i tap into harness from engine bay.i'm running an obd1 p28 at the moment. can someone tell me if this is correct if i'm wiring o2 straight to p28 ecu . help
4 wire 02
white wire=D4
black=A6
green=D22
black=A25
Old Apr 23, 2003 | 07:02 PM
dfoxengr's Avatar
Default Re: how do i wire up a 4 wire o2 to a p28 ecu (roc)
edit..read below
Old Apr 23, 2003 | 07:03 PM
dfoxengr's Avatar
Default Re: how do i wire up a 4 wire o2 to a p28 ecu (hybridvteceg)
edit, HA nevermind
in the cx..simple, dont even need to run to ECU unless you want...
white to white sender on stock CX harness...
1 black to switched ignition power, IE. when u turn the key on its on
the green and other black to ground.. thats all
5thGenFanatic
16
Aug 28, 2005 05:38 PM
BROKE.eg
Aug 5, 2005 05:02 PM
trooper0641
34
Apr 23, 2004 12:29 PM
1990hondaHF
11
Aug 21, 2003 09:29 AM
SprayinCX
Apr 12, 2003 08:45 AM
