possible to sleeve a B16 to 84.5mm or more ??
As far as I'm aware it isn't possible on a b16, although I dont know too much about all motor setups. I'm sure you could get there with a different crank and/or a deck plate, but you won't get to a full 2.0 with just sleeving.
Like another member mentioned earlier I don't believe you can get their with only sleeving you do need to upgrade the crank. I'm in the process of "finding"a gsr block to do the same thing but to 85mm instead. Trying to make a 2.0 monster for autox
