17.50 down the track whats wrong??
Old Apr 23, 2003 | 03:06 PM
Da Integra's Avatar
Default 17.50 down the track whats wrong??
hey anyone know what a 92 integra rs should pull on the track with a b16a swap?? i have dc sports header, obx cam gears ex- at 2 advanced and in- at 6 advanced, p28 ecu with gsr values on skunk 2 chip, full cat back exhaust, and intake with a act 6 puck extreme pressure plate. 17.5 doesn't sound right.
Old Apr 23, 2003 | 03:13 PM
mr.beeks's Avatar
Default Re: 17.50 down the track whats wrong?? (Da Integra)
maybe your reaction times???
Old Apr 23, 2003 | 03:14 PM
garados's Avatar
what was your reaction time, trap speed, and 60'?
Old Apr 23, 2003 | 03:15 PM
gsrvx's Avatar
New User
Default Re: 17.50 down the track whats wrong?? (FRANCISCO FLORES)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FRANCISCO FLORES &raquo;</TD></TR><TR><TD CLASS="quote">maybe your reaction times???</TD></TR></TABLE>
reaction time has nothing to do with ur ET
Old Apr 23, 2003 | 03:28 PM
Da Integra's Avatar
my reaction times are .050 to .065 and 60ft 2660. i really can eat up the tree!
Da Integra's Avatar
oh trap speed is 80 mph
Old Apr 23, 2003 | 03:31 PM
gsrvx's Avatar
New User
Default Re: (Da Integra)
EDIT: Sorry, just noticed u did post....is that a 2.6 60 ft? Try to get it down to 2.2.
Old Apr 23, 2003 | 03:41 PM
basmasta7's Avatar
Default Re: (RK)
even if he did get a good 60ft time, his 1/4 mile time would still suck ***. look at the trap speed he posted (80mph). that means he basically has no power. i think somethin's wrong with your engine cuz you should be pullin a lot harder than that.
Da Integra's Avatar
well i hearing people say my car should be faster then that. somewhere in the high 14's are they right??
Old Apr 23, 2003 | 03:43 PM
garados's Avatar
wait, why did you change your cam timing? do you have some aftermarket cams in there?
[HrZn]4life's Avatar
my b18b 98 teg with i/h/e, fpr pulls through the traps at 90 mph. You should definitely get your engine checked out....80 is extremely low meaning no power is being made. Good luck...
Old Apr 23, 2003 | 03:47 PM
bryan305's Avatar
my guess is you have your cams way off
Old Apr 23, 2003 | 03:49 PM
J337_UNIT's Avatar
Default Re: (garados)
if you dont have aftermarket cams in there and u changed your cam timing, you could be losing some major power. they can potentially squeeze a few HP from stock cams but you gotta run on a dyno to tune it right. and yea thats a really bad ET i think a geo metro could do better then that
Old Apr 23, 2003 | 03:52 PM
M-Type's Avatar
Default Re: (J337_UNIT)
did you break the engine in? or just decide to go to the track right away?
Old Apr 23, 2003 | 03:53 PM
Malice's Avatar
New User
i see DA's with B16's run 15's all day. your 60ft needs help. whats the condition of the motor?
Old Apr 23, 2003 | 03:54 PM
garados's Avatar
Default Re: 17.50 down the track whats wrong?? (bryan305)
I agree, don't advance the cams. Move them back to 0 and it'll be fine if you're running on stock cams. Trying to increase overlap (which I assume you're trying to do) with the stockers will most likely result in less power, I think.
Old Apr 23, 2003 | 05:27 PM
jonoknut's Avatar
Default Re: 17.50 down the track whats wrong?? (garados)
i here dyno tuning does wonders. . .
jon
Old Apr 23, 2003 | 06:31 PM
neo1z's Avatar
Default Re: 17.50 down the track whats wrong?? (jonoknut)
Well if he tuned the cams thats one thing -- but youre killing yourself with those cam advance guesses.
Old Apr 23, 2003 | 06:38 PM
EG(6)SR's Avatar
I actually heard that B16 integras do about as well as ls motors, due to the loss in torque. Could be wrong, but nevertheless, that MPH is way too slow if you didn't misshift, or stop through the track and coast. Compression and leakdown test will help you see the condition of your motor.
Old Apr 23, 2003 | 09:24 PM
gsrvx's Avatar
New User
Default Re: 17.50 down the track whats wrong?? (EG(6)SR)
That's what I'm thinking...it's probably under 110 ftlbs of tq and 140-150whp...I don't see high 14s...I see mid/high 15s
Old Apr 23, 2003 | 09:31 PM
UberTeg's Avatar
Default Re: ([HrZn]4life)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by [HrZn &raquo;</TD></TR><TR><TD CLASS="quote">4life]my b18b 98 teg with i/h/e, fpr pulls through the traps at 90 mph. </TD></TR></TABLE>
Anyways... thats what you get for swapping in a smaller motor into your car. You may want todo a compression and leakdown test.
Old Apr 23, 2003 | 11:06 PM
Regal's Avatar
Ladies and gentlemen we are floating in space...
Default Re: (UberTeg)
Unless there's something seriously wrong with your motor, I'm going with everyone else on the cam timing. The way your cam gears are set up doesnt sound right for stock cams, at all.
My advice would be to get some aftermarket cams and dyno tune it. Or just dyno tune it with the stock ones in, either way. Or....try pulling out the skunk2 cam gears and see what it runs. My guess is it's be a significant improvement
Old Apr 23, 2003 | 11:38 PM
iH8RICERZ's Avatar
Default Re: (Regal)
yeah 60ft sucks, air down your tires and launch higher! Also, i think your cam timing is off. Try driving your car w/ the cam gears set at 0 int and 0 exh. You might see a greater gain in power w/ just stock settings.
Old Apr 23, 2003 | 11:48 PM
AllmotorJunkie's Avatar
Your trap speed is really low. You should be in the 90's with a b16a
Old Apr 24, 2003 | 12:14 AM
2001gsRguy2's Avatar
im sorry...track newbie here..but whats trap speed? =\
