Antifreeze is Everywhere/ Help Please?
Ok, I have a hose busted, and leaking antifreeze everywhere. Does anyone know what size the hose is or where I can order the part from. This picture shows Heater Inlet Hose, however it does not give you the option to order. I checked Discount Auto Parts.net and they do not have it. It's the part that connect to the block. It looks as if it has been cut before so it seems shorter. Thanks for the help.
Modified by dabrown at 10:32 AM 4/25/2003
im not sure if your heater outlet hose is long enough, but you might be able to by-pass the heater core and go straight to the **** on the head for a temporary solution till you get the hose. Otherwise id just go to pepboys/advanced auto etc etc and walk in with a piece of the hose and tell them the length you want and they should match it up the size for you no problem and you should be good to go
jus go down to your local pep girls or whatever it's called in your area and pick one up, most likely they'll have it in stock or they can custom order it. or if u don't wanna wait they actually do make universal radiator hoses, they "look" kindda gay but hell, having a leaking hose looks even worst!
