obd2 to obd2 swap
Old Apr 23, 2003 | 06:43 AM
ASHY-ELBOW's Avatar
Default obd2 to obd2 swap
i am planning on swapping a 96 ls motor into a 96 civic dx, i searched here and read the hybrid garage page but it does not say much abiout this kind of swap. My question is can i use the same harness that comes with the car ? or do i need to change it over to a ls harness
Modified by ASHY-ELBOW at 3:44 PM 4/27/2003
Old Apr 23, 2003 | 06:52 AM
Finest's Avatar
Default Re: obd2 to obd2 swap (ASHY-ELBOW)
I'm pretty sure you can keep your harness...you'll probably have a few connectors left over because you're not using any VTEC wires.
Old Apr 24, 2003 | 01:06 PM
ASHY-ELBOW's Avatar
Default Re: obd2 to obd2 swap (98CTRCoupe)
oops my bad its a 96 dx no vtec will the ecu plug right in? along with the engine harness? thx for info guys
Old Apr 24, 2003 | 01:30 PM
Katman's Avatar
You have to reuse your DX harness on the LS motor since all 96-00 civics use a 1 piece engine harness (integra have a 2-piece engine harness which are not comptible w/96-00 civics). There shouldn't be any vtec wiring on either harnesses. But even if you did, its ok if there's vtec wiring/plugs on the harness; you'll just leave those items unplugged/dormant.
The LS ecu should plug and play with your car since both vehicles are 96.
Old Apr 24, 2003 | 02:52 PM
ASHY-ELBOW's Avatar
Default Re: obd2 to obd2 swap (Katman)
so just take the harness off the dx and put it on the ls motor and that should be it?
Old Apr 24, 2003 | 03:38 PM
Katman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ASHY-ELBOW &raquo;</TD></TR><TR><TD CLASS="quote">so just take the harness off the dx and put it on the ls motor and that should be it? </TD></TR></TABLE>
Thats right.
Old Apr 24, 2003 | 03:40 PM
Lord Helmet's Avatar
yeah just make sure you use ALL of the emissions equipment from that ls engine if you're worried about the smog test.
Old Apr 26, 2003 | 08:37 PM
ASHY-ELBOW's Avatar
Default Re: obd2 to obd2 swap (sleeperciv)
kewl thx guys anyone know of any sites that describe this swap? other than hybrid garage?
Old Apr 27, 2003 | 05:15 AM
VTECVillain's Avatar
By reusing your stock EX engine harness, it will make the swap plug and play for the most part. You might have to extend some wires but other than that everything will plug in as long as you stick with a 96-98 B18B1 complete motor and ECU.
Old Apr 27, 2003 | 06:47 AM
ASHY-ELBOW's Avatar
Default Re: obd2 to obd2 swap (VTECVillain)
sorry i changed the post its a dx but i have been reading a bit so it seems that i take the dx harness off the dx motor and then put it on the ls motor and use the ls ecu. I see that i will have to extend a few wires and use a SI rear engine mount and the civic driver side mount and for my ac use a delsol vtec ac bracket?
anything else i should need i know i need the axles shift linkage ect but what about radiator hoses? thx guys this will make teh swap go so easy for me(i hope lol)
got00rice
May 15, 2009 05:53 AM
mustang5.slow
May 19, 2007 09:14 PM
ShowtimesDC2
Sep 7, 2003 05:53 PM
sydag5
Oct 7, 2002 11:47 PM
HondaCutter
Sep 19, 2002 01:10 PM
