Wheel specified for each corner?
Old Apr 23, 2003 | 05:12 AM
Nuts's Avatar
Default Wheel specified for each corner?
On the wheels CP-035 that I've got 2 days ago, there are stickers on each wheel to indicate which corner they should be mount. (left-rear in the picture below), is that an indicator for the tires or the wheels itself? (never heard of a wheel have to be mounted on a specific corner before, but then I could be wrong.) any thoughts?
Old Apr 23, 2003 | 06:07 AM
Nuts's Avatar
Default Re: Wheel specified for each corner? (CS)
anyone?
thanks,
CS
Old Apr 23, 2003 | 06:10 AM
.RJ's Avatar
.RJ
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CS &raquo;</TD></TR><TR><TD CLASS="quote">anyone?
thanks,
CS</TD></TR></TABLE>
Relax.....
Old Apr 23, 2003 | 07:42 AM
FyrFytr's Avatar
From what limited knowledge I have on this subject:
If it is a unidirectional tread design (I think that's the correct word) then the tire is only designed to roll in one direction, therefore, putting it on "backwards" is detrimental to the tire's performance. I am assuming that you received these with the tires mounted & balanced on the wheels.
Old Apr 23, 2003 | 07:47 AM
Floyd's Avatar
Default Re: Wheel specified for each corner? (.RJ)
Is the sticker from the wheel manufacturer? If so, then it wouldn't have anything to do with the tires that are mounted. Maybe it's just a way of keeping a set of 4 together.
miggy23
17
Mar 7, 2010 06:37 PM
gyrmaersk
Apr 21, 2006 12:57 AM
whitelsteg
Mar 28, 2004 06:52 PM
DOHCon15s
Feb 18, 2004 07:36 PM
performula
12
Sep 11, 2002 07:49 PM
