JDM ITR HID beam adjustment
Old Apr 23, 2003 | 03:57 AM
superfuji57's Avatar
Default JDM ITR HID beam adjustment
I found the bolt to adjust the low beams horizontally, but i couldn't find (from looking it at bolted on under the hood anyway) one for vertical adjustment. Also, my right foglight seems to be aiming higher than my left one, is there a separate adjuster for that too? And how do you know when your not aiming too high or too low since there is no leveler on them?
TIA
Old Apr 23, 2003 | 06:15 AM
canuck-mx6's Avatar
Default Re: JDM ITR HID beam adjustment (superfuji57)
There is an adjuster for the low beam vertical, the high beam vertical, and the horizontal. I do not remember there being an adjuster for the fogs, but I never really looked for one
Old Apr 23, 2003 | 07:25 AM
98R-1144's Avatar
Default Re: JDM ITR HID beam adjustment (canuck-mx6)
i'm pretty sure there is an adjuster for the fogs.. unless i was drunk as hell when i "thought" i was adjusting it. or it was the high beam i was adjusting and i thought the fog was moving with it... lol
i'll take a looksee tonight.
Old Apr 23, 2003 | 07:04 PM
Oops I meant to say I found the vertical adjuster, I need to find the horizontal one.
Thanks!
Old Apr 23, 2003 | 07:33 PM
zer0zer0 TypeR's Avatar
Default Re: (superfuji57)
to get the the horizontal one, you need to insert a screwdriver on the top outside part of the headlights located near the fenders. There should be holes in the radiator support where you can stick a screw driver to adjust the beams.
Spartan500
Sep 6, 2007 06:07 PM
Jowee
Nov 21, 2004 03:54 PM
One Bad GeeSeeR
Jan 31, 2004 07:19 PM
CIVIC dude
Mar 1, 2003 11:57 AM
