Glue on Indiglos
Old Apr 22, 2003 | 11:44 PM
Importteg95's Avatar
Default Glue on Indiglos
Indiglos were glued to stock gauges when installed. im sick of them now and i wanna go back to stock. Any way of just being able to take off the indiglos and still use the stock gauges. im sure theres gonna be glue on stock guages; but is there anyway of cleanin that glue off properly?? or am i just stuck with them now.
Old Apr 23, 2003 | 12:26 AM
Broken Gearbox's Avatar
Default Re: Glue on Indiglos (Importteg95)
try using some of that sticker remover stuff...dont know what its called...
Old Apr 23, 2003 | 12:46 AM
xteg95's Avatar
Default Re: Glue on Indiglos (s_o_h_c)
try goo gone that stuff does wonders.
Old Apr 23, 2003 | 06:29 AM
Eluzions047's Avatar
go down to the hardware store and pick up some adhesive remover. That should work, but remember only use a light portion of it and rub hard, if not your gauges will turn to this ugly smudge whitish color.
Old Apr 23, 2003 | 09:59 AM
Default Re: Glue on Indiglos (Eluzions047)
Would goo be gone be considered an adhesive remover? ya im just worried about smudging up the numbers or lines on the gauges.
Old Apr 23, 2003 | 11:57 AM
yeah, it's consider one of it, but make sure don't use too much of it. Afterward if you apply a coat of windex to it, that should help out too.
Old Apr 23, 2003 | 02:28 PM
95 Gizzer
Guest
Posts: n/a
That happened to me, and so far the superglue residue is still on my gauges. I dont even notice it anymore, but its hella ugly. Nothing I've tried has worked so far, but I'm gonna try to get some of that superglue remover from a hardware store and see how that works. If you try that, let me know how it turns out
Old Apr 23, 2003 | 06:23 PM
slomob18b's Avatar
Default Re: Glue on Indiglos (95 Gizzer)
I had superglue residue on my gauges too after I removed my indiglos back in the day. I ended up buying a whole new cluster off of ebay for cheap. I just swapped out the temp, rpm, and fuel gauges since my speedo was not too bad. Damn indiglos heh
Dancing is Forbidden
Oct 9, 2005 01:37 PM
91hondacrx
Aug 4, 2003 11:01 PM
Civicexb16a2
Sep 5, 2002 11:05 AM
snake01
Mar 20, 2002 10:31 PM
GQ 05YellowEVO8
Jun 19, 2001 08:32 PM
