Aux Input for my Factory Radio - Prelude
Old Apr 22, 2003 | 07:38 PM
davem's Avatar
Default Aux Input for my Factory Radio - Prelude
I have the stock factory radio for my prelude... i like it cause it works fine (and it's an alpine), but i have a car-dvd player that has rca outputs and i want to be able to hook that up to my factory stereo. I know you can hook up an alpine CD changer to the radio so i was wondering if there was an adapter that would give me rca inputs to plug directly into the radio (for best sound quality)?
I know i could use an FM modulator but those usually sound like ***... unless you know of one that is surprisingly good, i would rather find a way to hook the RCA inputs directly up to the radio.
Old Apr 22, 2003 | 08:14 PM
philly-O's Avatar
Default Re: Aux Input for my Factory Radio - Prelude (davem)
fm mod is what i was going to recomend. btw, how do figure that your factory stereo is am alpine? just cause you can plug a alpine changer into it doesnt mean its an alpine. you still need an adaptor to make it work. if i remember to check at work tomorrow, i will look at my perepheral book to see if they make an aux input piece for the changer plug. i dont think they make one for your car but they do for others like the newer beamers.
Old Apr 22, 2003 | 11:06 PM
dc24me's Avatar
Soundgate makes auxillary input adapters that plug into the OEM CD changer input. I'll have to double check @work too, but I'm 99.99% sure they have a Honda application, but I've never seen one before since most people with Hondas are willing to change their deck. Blitzsafe makes one.
You can probably even try using a 98-02 Honda to Alpine M-bus changer adapter (~$90) along with a Alpine KCM122B M-bus to dual male RCA aux input adaptor cord ($15.99).. that would probably work too.
Old Apr 23, 2003 | 06:00 PM
davem's Avatar
Default Re: Aux Input for my Factory Radio - Prelude (dc24me)
Cool... thanks for the answers. I will wait and see what you guys come up with. I don't want to do the MBUS thing cause that would make it too expensive! I was just looking for a cheap $10-$30 solution.
I got the pinout for the din and they have Left & Right input pins, so i was thinking that one of the other pins must be a voltage or something telling the radio that it is hooked up to a changer (so when you hit the CD button it allows that option to be chosen)... if i figure that out then maybe it will work and i can hook my input signals directly to those other two pins. I know one of the pins is a data bus, that prolly tells the changer what disc to choose and etc... but since all i need it to do is just have an RCA input into my radio then i can ignore that pin. ideas?
Old Apr 24, 2003 | 12:00 AM
b20guy's Avatar
Try HON-AUX at http://www.pie.net. Might be what you are looking for...
Old Apr 24, 2003 | 10:57 PM
davem's Avatar
Default Re: Aux Input for my Factory Radio - Prelude (b20guy)
Thanks B20GUY! That looks like exactly what I need!
Click here for the exact part needed for Honda's
I'll write up how good it is once i order/test it.
Old Apr 25, 2003 | 08:39 AM
rjr162's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dc24me &raquo;</TD></TR><TR><TD CLASS="quote">Soundgate makes auxillary input adapters that plug into the OEM CD changer input. I'll have to double check @work too, but I'm 99.99% sure they have a Honda application, but I've never seen one before since most people with Hondas are willing to change their deck. Blitzsafe makes one.</TD></TR></TABLE>
Just be warned! We tried using a soundgate adaptor on a 2003 toyota, and without the XM box being plugged into the adaptor... we plugged it into the factory radio and *poof* smoke. Doubt you'll have that problem but my first experience with one of their adaptors, and it didn't make a good impression
Old Apr 26, 2003 | 02:42 PM
b20guy's Avatar
Please do. I am interested in knowing how well it works, how the sound quality is, etc.
Old Feb 3, 2004 | 01:28 PM
weakGOODJunKieS.com's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by davem &raquo;</TD></TR><TR><TD CLASS="quote">Thanks B20GUY! That looks like exactly what I need!
does this only work if the head unit has a cd changer? i have 98 integ with oem am/fm cd player, no cd changer..
iJDMBB6
May 2, 2007 04:07 AM
20ls01
Audio / Security / Video
10
Mar 20, 2007 11:38 PM
Malachi
Mar 29, 2003 06:58 PM
girlRacer
Nov 11, 2002 06:39 AM
