What's the advantage to an aftermarket LCA?
Old Apr 22, 2003 | 03:47 PM
24valvage's Avatar
Default What's the advantage to an aftermarket LCA?
Like the title says; What are the advantages or disadvantages to an aftermarket LCA(rear)? Other than the bling bling factor, that is.
Old Apr 22, 2003 | 03:51 PM
bryan305's Avatar
Default Re: What's the advantage to an aftermarket LCA? (24valvage)
a little lighter than stock
Old Apr 22, 2003 | 05:34 PM
24valvage's Avatar
Default Re: What's the advantage to an aftermarket LCA? (bryan305)
That's it? Just for the look and because it's lighter?? Do stock LCA's actually weigh a lot ??
Old Apr 22, 2003 | 06:18 PM
RICE POLICE SIP's Avatar
are they stronger?
Old Apr 22, 2003 | 09:14 PM
bryan305's Avatar
Default Re: What's the advantage to an aftermarket LCA? (92boostn'hatch)
mabye a little stronger = less flex...but like you're actually going to be able to tell
Old Apr 22, 2003 | 09:20 PM
Ash J. Williams's Avatar
Good, Bad…I'm the one with the gun
From: Trapped in time, Surrounded by evil, Low on gas
SRR ones?
they allow you to run wider tyres, better camber control and they are ANODIZED!!
stan
Old Apr 22, 2003 | 10:23 PM
martini's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 24valvage &raquo;</TD></TR><TR><TD CLASS="quote">That's it? Just for the look and because it's lighter?? Do stock LCA's actually weigh a lot ??</TD></TR></TABLE>
it's not just any weight, either. That is unsprung weight.
Old Apr 22, 2003 | 11:19 PM
EF-9SiR's Avatar
Default Re: What's the advantage to an aftermarket LCA? (martini)
arent some adjustable so u can adjust camber?
andylawcc
Suspension & Brakes
28
Oct 10, 2006 07:48 PM
ace_cr
May 1, 2004 02:32 AM
grandmasterflex
Dec 10, 2003 01:20 PM
mister2racer
Aug 17, 2003 04:33 PM
RaVAGE00
Jun 9, 2003 08:36 AM
