Anyone have a picture of their fuel rail they can show me?
Old Apr 22, 2003 | 12:22 PM
FourthGenHatch's Avatar
Default Anyone have a picture of their fuel rail they can show me?
I've done my ZC swap into my DX. However the fuel hose doesn't bolt up to the thing on the ZC fuel rail, its not the same. My DX one had a connection like this...
But my ZC has like a bolt with the hole in the center. Am I missing a piece of my ZC engine or something?
Old Apr 22, 2003 | 12:25 PM
CHRIS 1.8's Avatar
Default Re: Anyone have a picture of their fuel rail they can show me? (FourthGenHatch)
That is not a fuel rail. Thats a fuel pressure gauge. You can mount that gauge on your fuel filter.
Old Apr 22, 2003 | 12:28 PM
Default Re: Anyone have a picture of their fuel rail they can show me? (CHRIS 1.8)
I'm aware of that, I'm not talking about the regulator, I'm talking about the fitting. The like bolt with a hole on one side. Thats how my old engine was, my new one is like a bolt with a hole down the center. I will go take pictures and show you guys...
Old Apr 22, 2003 | 12:37 PM
See they aren't the same like everyone says the should be. Do I need an Integra hose or something?
Old Apr 22, 2003 | 12:44 PM
drjondurst's Avatar
Thats weird man. Maybe you are missing a peice, do you have the "top" that screws onto the "nipple" coming off the fuel rail? I forgot how mine is, but I'll check on my way out the door in a sec and I'll post it when I get back from work if no one has helped u yet.
Old Apr 22, 2003 | 12:48 PM
Default Re: (drjondurst)
Ok I kept my DX intake manifold do you think I can harvest these parts off of that?
Old Apr 22, 2003 | 01:56 PM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
Default Re: (FourthGenHatch)
picture 1. This is the stuff you will need...
picture 2. The line on the left is a DX,notice the one on the right has a larger opening. Where the DX line fees through the middle,The Si type line feeds through one end..
Old Apr 22, 2003 | 02:17 PM
mycvc8u2's Avatar
click on my link in my sig and look at the engine pics
Old Apr 22, 2003 | 08:00 PM
Default Re: Anyone have a picture of their fuel rail they can show me? (mycvc8u2)
So if I go to a junkyard will most any MPFI Honda one work? Also I don't really see how the O shaped ring fits onto the bolt with the hole in the center. How the hell does gas get inside it?
Old Apr 22, 2003 | 08:25 PM
RCautoworks's Avatar
I had the same problem with my b16, I drilled a new hole in my fuel rail and used my dx lines. It worked great and I never had a problem using my old dx fuel lines. Just curious though, would using my old dx lines cause any problems ? I have been driving the engine with my old lines and my fuel and air mixture seems good.
Old Apr 22, 2003 | 08:35 PM
Default Re: Anyone have a picture of their fuel rail they can show me? (90blackcrx)
The bolt is too fat for the ring on mine so even if I drilled it it wouldn't fit on.
Old Apr 22, 2003 | 08:41 PM
What about the bolt from the dx ?
Old Apr 23, 2003 | 06:00 AM
Do you think these "bolts" can be removed like studs? I think I may try it.
Old Apr 23, 2003 | 09:04 AM
For some reason I thought you were talking about the nut.
unknown0001
Jun 22, 2007 12:36 PM
loki17
Apr 10, 2004 04:28 PM
sabertooth
Dec 9, 2003 03:50 PM
pelotudo
15
Feb 8, 2003 08:32 AM
Hondasaurs
Nov 7, 2001 02:56 AM
