can the 5th gen suspension be bolted up to the 4th gen?
When you say suspension do you mean just springs and shocks or do you mean everything like the upper control arms, lower control arms, forks, radius rods and knuckles. If you mean the later, I don’t think a 5th gen will just bolt up, especially the front Type SH suspension since it is even more different.
i mean just what i need to get to switch it to the 5 lug... i dont know what parts exactly I will need... so if someone can inform that would be great
Well **** why didn't you say so in the beginning if that is all you were wanting to do
All you will need to do is replace the hubs and rotors to do a 5 lug onversion if you already have a 4th gen VTEC. Now if you have a SI or S 4th gen Prelude it will take some custom work likely.
Why custom work on a 92-96 Si or S. The only difference in the S, SI and Vtec, besides the motor is the front brakes, Vtec bigger rotor and caliper. As far as the suspension is concerned.
Well I am no expert on 4th gens but if you wanted to use the 5th gen hubs and rotors and if you wanted to get the 5th gen brake calipers to mount to your 4th gen SI knuckle it would likely take a custom caliper mounting braket like AEM uses on their Big Brake kit. Maybe you could find smaller 5 lug rotors from another car that would let you keep your 4th gen calipers.
after installing 4th gen and 5th gen springs, I can tell you the suspension is not completely interchangeable.
the upper control arm in the front bolts to the frame in a completely different way. (in a very annoying way on the 5th gen)
is there a aem big brake kit i could use... to be able to have the 5 lug... and at the sametime the aem kit...with the bigger rotors, and calipers and etc...?
the dealer will tell you no. but you can do it I got the parts for a guy from a local yard and sent them to him. He e mailed me and said it worked perfect. they have a few of them at the yard if want I can check on mon . That one he gave me the comp sus for 400 and with wheels and tire he would have wanted 650
vtecfiendsh
Mar 2, 2003 10:53 AM
