trouble shooting fuel-pump
Old Apr 22, 2003 | 11:46 AM
Rob Dizzle's Avatar
Default trouble shooting fuel-pump
My car is having some hesitation that has started up within the last few days.
I had a similar issue before, but that was from my intake manifold not being torqued down properly.
When the car is cold there is no problem. After the car is warmed up it starts having issues.
At lower rpm's and part throttle the engine will bog down when I am trying to accelerate.
I havent checked timing yet
But, after 4k rpm it runs fine
any portion of vtec runs fine as well 5k-9k
no cel's
the car idles, but its kinda rough idle. i could care less about the idle. I just want it to run regular when driving around
edit: there isnt much trouble shooting listed in the hemls manual under the fuel pump. it only trouble shoots to see if it is working or not (like completely dead)
Old Apr 22, 2003 | 01:00 PM
Tweakmeister's Avatar
Default Re: trouble shooting fuel-pump (Bob-DC2)
fuel filter?
Old Apr 22, 2003 | 01:17 PM
JimBlake's Avatar
I imagine if the filter were clogged or the pump was running bad (slow??) it would be most noticeable at high revs, high load. After all, that's when the engine uses the most gas.
Besides, I think pumps either run OK or they don't run at all.
Check spark timing. Is there any reason to suspect cam timing? If so, check that first, then check spark timing.
Check your coolant temperature sensor. If the ECU thinks the engine's still cold, it'll use wrong mixture. But if that's it, why doesn't it throw a CEL?
Old Apr 22, 2003 | 02:23 PM
Rob Dizzle's Avatar
Default Re: trouble shooting fuel-pump (JimBlake)
no codes
put a new fuel filter less than 1k miles ago
i have rc310 injectors with less than 10k on them
Old Apr 22, 2003 | 02:37 PM
have you inspected cap and rotor? (I know it sounds odd...but it's also a "weak point" of the system).
Old Apr 22, 2003 | 10:31 PM
Rob Dizzle's Avatar
Default Re: trouble shooting fuel-pump (Tweakmeister)
Iam going to break down and buy a stupid timing gun, even though I will only use it 2x (hopefully)
i will check timing and see whats up and also take of the distributor
I cant remember off hand when I had a new cap & rotor put on
but why would it be temp dependent? it works fine when cold then warm it is wacky. and also above 4.7~k rpm it works completely fine?
Old Apr 23, 2003 | 04:51 AM
JimBlake's Avatar
Take off the distributor cap & look for evidence of anything burned or messed up. Cap & rotor & plug wires can get flaky with temperature, but I usually get it backwards. In other words, they're flaky when cold & damp; start working OK when hot.
But maybe the coil & ICM inside the distributor can get worse when they get hot? But if so, I don't understand why they'd be OK at high revs...
Old Apr 23, 2003 | 02:12 PM
Rob Dizzle's Avatar
any other ideas?
I still havent figure it out yet
Old Apr 23, 2003 | 02:51 PM
hoot.10's Avatar
Sounds more like a vac leak to me
fryman
Aug 21, 2008 02:00 AM
wesleywhite989
18
Aug 11, 2008 05:38 PM
letholone
May 8, 2005 02:50 PM
