dumb questions??
im not a crx guy so these questions might sound stupid,im trying to help a freind.
can you use a 93 teg ecu when doing a swap into a crx? (93 teg ls motor)
if so what all needs to be changed?
if not ,then what ecu does he need?
thanx alot and im sure he will be most grateful
I'm not 100% sure but I know 93 Integra was OBD-1 and the CRX was OBD-0. I think the plugs that connect the ECUs are not the same. You might have to modify that to get it to work or something.
I believe '90-'91 integras were pre-obd or OBD 0 and '92-'93 were OBD 1. So, you'd have to convert to OBD 1. I honestly can't tell you exactly what that involves, but plenty of other people can.
HTH
HTH
From: yea thats right i got a flowmaster and it owns you, Oklahoma, usa
http://www.hasport.com sells an odb converter for like 200 bucks or so you might check that for the odb0 to odb1 conversion. although if your doing a b16 in the crx the ls ecu isnt chipped for vtec so that would probably cause a problem their although with a zc i wouldnt think it would pose too much of a problem. good luck
haccord550
Mar 13, 2005 08:55 PM
CRX_GUY_123
Mar 23, 2004 08:22 PM
civictypenos
Apr 23, 2003 06:50 PM
