QUICKIE: H&R sport srpings the same
Old Apr 22, 2003 | 09:34 AM
216.226.142.95:27016's Avatar
Default QUICKIE: H&R sport srpings the same
are H&R sport springs all the same for all model of 94-01 integra? i ordered a set for a gs but i have a gsr, there would be no problem correct? the drop and spring rate will be the same?
Old Apr 22, 2003 | 09:39 AM
tilt's Avatar
Default Re: QUICKIE: H&R sport srpings the same (216.226.142.95:27016)
all but the itr are the same
96-97 Integra Type R HR-29502
94-01 Integra HR-50145
Old Apr 22, 2003 | 09:40 AM
split917's Avatar
yes, it is the same for all G3 tegs.
H&R Sport 1.75"(f) 1.5"(r) 276 lb/in(f) 276 lb/in(r)
except for the itr, like metioned above.
Old Apr 22, 2003 | 09:43 AM
neo1z's Avatar
Default Re: QUICKIE: H&R sport srpings the same (split917)
God I hate those spring rates...Lowers way too much for such soft rates.
Old Apr 22, 2003 | 10:04 AM
Default Re: QUICKIE: H&R sport srpings the same (neo1z)
thanks guys
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by neo1z &raquo;</TD></TR><TR><TD CLASS="quote">God I hate those spring rates...Lowers way too much for such soft rates.</TD></TR></TABLE>
is it? from what i know the spring rates are 276 front and back for sports and stock rates are 212 lb/in front and 117 lb/in back. big diffrence in the back but at the front is not that big of a diffrence. ill only get shocks for the rear for the mean time
Old Apr 22, 2003 | 10:13 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by split917 &raquo;</TD></TR><TR><TD CLASS="quote">yes, it is the same for all G3 tegs.
except for the itr, like metioned above.</TD></TR></TABLE>
HA! BS! My car on H&R Sports is lowered somewhere around 2.5-3"! That is WAY too low for only 276 lb/in rates. The car looks great but I will be going w/ 350/400 f/r GC coilovers set to about the same drop (probably 5mm higher than it is right now for the back, but the same for the front).
*edit* just to be clear, they do not have any sagging problems, this 2.5-3" drop has been there since they were installed over a year ago. My front Koni perches on the top stock height setting. My rear Konis are on the lowest setting so it's about a 3" drop back there.
Old Apr 22, 2003 | 10:59 AM
SMZ GSR's Avatar
Default Re: QUICKIE: H&R sport srpings the same (PatrickGSR94)
they're supposed to lower 1.75", mine went to between 1.75 and 2, closer to 2 though
Old Apr 22, 2003 | 11:10 AM
fiebru1119's Avatar
Default Re: QUICKIE: H&R sport srpings the same (SMZ GSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SMZ GSR &raquo;</TD></TR><TR><TD CLASS="quote">they're supposed to lower 1.75", mine went to between 1.75 and 2, closer to 2 though</TD></TR></TABLE>
same here.. mine are sitting ~1.9 F and ~1.6 R
Old Apr 22, 2003 | 11:28 AM
GreenD's Avatar
Default Re: QUICKIE: H&R sport srpings the same (fiebru1119)
u shouldve gotten the 29502. 360f, 320r linear rates w/ the same ride height as the 50145.
Old Apr 22, 2003 | 12:14 PM
majeed11's Avatar
Default Re: QUICKIE: H&R sport srpings the same (GreenDestiny)
I have H&R Sports, but I got the ones made for the Type-R.
I have not measured the drop, but it seems to be a tad lower than 1.7 in the front. Take a look at this video.
It's with stock shocks... notice the bouncing at times..... but note that I'm on stock shocks.
Heres the link to the video: http://www.majeed.ca/majeedmob...e.mov
Old Apr 22, 2003 | 12:22 PM
Aaron M's Avatar
Default Re: QUICKIE: H&R sport srpings the same (majeed11)
great springs, but get custom GC's if you have the money. I wish I did....
Old Apr 22, 2003 | 01:44 PM
newblueteg's Avatar
It should be fine, because when I ordered the H&R's for my car, the only two options were standard Integra (LS, GS, GSR) or Type R.
litterbox
Apr 16, 2005 02:19 PM
DIRep972
Mar 13, 2004 05:55 PM
p1ccoloz
Dec 31, 2003 02:15 AM
93EH6
Jan 15, 2003 01:56 PM
ALF
Jul 28, 2001 10:22 PM
