Crank Pulley
Old Apr 22, 2003 | 09:00 AM
VisualEcstasy's Avatar
Default Crank Pulley
can anyone show me a picture of what the timing and tdc marks look like on the crank pulley. mine are wore off pretty bad. i can barely tell anything is there and i am tryin to get an idea of about how far the marks are apart so i dont confuse them with anything else.
Old Apr 22, 2003 | 09:49 AM
NiiS's Avatar
Default Re: Crank Pulley (BurntRice009)
The yellow circle is what you`re aiming for, NOT the lines further toward the front of the car...GL
Old Apr 22, 2003 | 09:53 AM
monicle's Avatar
the true mark is on the gear behind the pulley take the pully off and use the gear to be sure. More trouble but more definate.
Old Apr 22, 2003 | 10:00 AM
NiiS's Avatar
Default Re: Crank Pulley (monicle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by monicle &raquo;</TD></TR><TR><TD CLASS="quote">the true mark is on the gear behind the pulley take the pully off and use the gear to be sure. More trouble but more definate.
They are dead nutz accurate either way, there is no way the crank pulley can move from where it`s at...
Old Apr 22, 2003 | 10:03 AM
thanks for your help...one last question...on the cam gear itself on the D16Y8...i noticed other honda have a sorta solid cam gear with the word UP on it and two lines that line up with the top of the head or whatever...but mine is like a star it has 5 arms and just the word UP on it. how can i be sure to get the cam timing right with the crank.
Old Apr 22, 2003 | 10:09 AM
NiiS's Avatar
Those marks are the key to successful time. They must be absolutly perfect tho
Old Apr 22, 2003 | 02:40 PM
Default Re: Crank Pulley (sinister)
thanks
Old Apr 22, 2003 | 02:44 PM
IS3Fifty's Avatar
how about on aftermarket cam gears like STR, I have them for my b18c. I need some help with adjustment for optimal timing. As soon as i get it done, I will post pics and a how-to tech article.
misterpsycho
Oct 28, 2008 05:23 PM
Themouse
Feb 3, 2008 08:29 PM
redzcstandardhatch
Jul 22, 2007 03:44 PM
twistedbydezign
Sep 24, 2005 02:10 PM
Kevin
May 17, 2002 08:51 AM
