450 dsm injectors in 95 DX
Old Apr 22, 2003 | 06:43 AM
digitalhav0c's Avatar
Default 450 dsm injectors in 95 DX
i was wondering what all i need to run 450 dsm injectors in my civic its 95 dx coupe. Will i need a resistor box or not i have some people tell me i do and some say i don't. if i do need a resistor box could some one point me in the right direction to wire them up. thanks
Old Apr 22, 2003 | 06:45 AM
Spade's Avatar
Default Re: 450 dsm injectors in 95 DX (digitalhav0c)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by digitalhav0c &raquo;</TD></TR><TR><TD CLASS="quote">i was wondering what all i need to run 450 dsm injectors in my civic its 95 dx coupe. Will i need a resistor box or not i have some people tell me i do and some say i don't. if i do need a resistor box could some one point me in the right direction to wire them up. thanks</TD></TR></TABLE>
What mods do you have. May be way too much fuel.
Old Apr 22, 2003 | 07:20 AM
Canuk_SiR's Avatar
Default Re: 450 dsm injectors in 95 DX (Spade)
you'll need a resistance to the ground side of the injectors. You can use a resistor box (out of an 88-91 Si, or the older integras) or you could use 10 ohm resistors wired inline with the wire. I've heard that wiring them inline will shorten the life of the resistors, since the resistor box gets rid of the heat better, but how good can a 12-15 yr old resistor box be anyway? Aside from the resistors you'll need the clips (if the oem ones won't fit) and that's it. Then all you have to worry about is trying to control them.
how are you running them anyway? what fuel control are you using? (standalone? hondata? afc hack? )
Old Apr 22, 2003 | 07:23 AM
SI_DRIVR's Avatar
Default Re: 450 dsm injectors in 95 DX (Canuk_SiR)
The injector connectors will work. You will have to cut a little tab off the DSM injectors to make them fit though
C-speed
Dec 4, 2008 09:43 PM
JDM Vision
Jun 25, 2006 01:23 AM
BrothaSit
Jan 9, 2006 09:20 PM
tgreaves
Oct 31, 2003 10:27 AM
Boosted LS
Jul 9, 2003 08:52 AM
