replacing plastic inner door seals (the moisture barrier sheets).. what adhesive?
Old Apr 22, 2003 | 06:14 AM
reno96teg's Avatar
Default replacing plastic inner door seals (the moisture barrier sheets).. what adhesive?
so, seeing as i've taken apart my door and pulled that seal down about 2-3 times now, it's cracked and ripped all over the place and basically falling apart. so, i've decided to cut myself new seals (instead of paying ~$20ea for new ones).
my question is, what's the best adhesive to go with? what's there is not your typical adhesive. it's some sort of rubbery sticky stuff. like that gum stuff used to hang posters on walls (can't think of the right name).
tia!
Old Apr 22, 2003 | 07:01 AM
Lenguaso's Avatar
3M makes a spray on adhesive. They sell it at Home-Depot
Old Apr 22, 2003 | 07:11 AM
reno96teg's Avatar
Default Re: (Lenguaso)
isn't that thin and liquid-like though? i need something thick and rubbery (please refrain from the jokes.. )
Old Apr 22, 2003 | 07:15 AM
Lenguaso's Avatar
I've personally used it on many occasions. It's semi-liquid like. But not watery. It's very good stuff.Works good.
Old Apr 22, 2003 | 08:53 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: replacing plastic inner door seals (the moisture barrier sheets).. what adhesive? (reno96teg)
Just look for any sort of adhesive that comes in a caulk tube that will not harden over time, something that stays flexible.
r33dm0n3y
Feb 18, 2009 04:35 PM
akeldama
Audio / Security / Video
May 17, 2003 03:36 PM
p0pe
Mar 18, 2002 03:31 PM
bemathew
Sep 16, 2001 09:01 AM
