Camber Wear... how long will my tires last?????
Old Apr 21, 2003 | 10:03 PM
SleekBlkPrelude's Avatar
Default Camber Wear... how long will my tires last?????
i did a search and found nothing regarding my specific question.
i just got 17's wrapped in toyo fz4 (300 treadwear) on my 5th gen. my car is dropped approx. 2" on gc w/ koni sports. From a glance you can't tell the rims are slanted. i went to get an alignment and the ppl told me it was pointless unless i had a camber kit. CAMBER KITS ARE EXPENSIVE. plus from the look of it, the fronts are about .5-1 degree off, and the rear are about 1.5 degrees off. they don't look bad at all... i drive like a responsible conservative adult, but i do make hard turns from time to time... my specific question is:
HOW MANY MILES CAN I GO BEFORE I NEED TO REPLACE THE TIRES??? please give me a good guess, that will be good enough for me. Thanks.
Old Apr 21, 2003 | 10:06 PM
smslude's Avatar
Default Re: Camber Wear... how long will my tires last????? (SleekBlkPrelude)
I guess it just depends on how hard you drive and so on, im not really sure how big of a deal that would make, i didnt have a camber kit on my accord and the camber was noticably off, i drove on Kuhmo 712 pretty hard for about 6 months until i sold the wheels. A camber kit shouldnt be too expensive.
Old Apr 21, 2003 | 10:07 PM
smslude's Avatar
Default Re: Camber Wear... how long will my tires last????? (smslude)
400 Posts SWEET
Old Apr 22, 2003 | 04:23 AM
si93lude's Avatar
I just got an alignment, still wears the tires out evenly.
Old Apr 22, 2003 | 06:50 AM
del_parker's Avatar
I used one full set of tires, kumho 712-205/55/15s, without a camber kit and they lasted 7 months and roughly 15k miles. I have a similar drop with an eibach pro kit and neuspeed/koni yellows. I do notice the tires are lasting longer now since I've installed the ingalls kit up front. The rears don't really wear that quickly.
Old Apr 22, 2003 | 09:54 AM
PilotSi's Avatar
Default Re: Camber Wear... how long will my tires last????? (del_parker)
Make sure your toe is in check. It's not camber that does the most damage...it's toe AND camber...
David
Old Apr 22, 2003 | 12:59 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by del_parker &raquo;</TD></TR><TR><TD CLASS="quote">I used one full set of tires, kumho 712-205/55/15s, without a camber kit and they lasted 7 months and roughly 15k miles. I have a similar drop with an eibach pro kit and neuspeed/koni yellows. I do notice the tires are lasting longer now since I've installed the ingalls kit up front. The rears don't really wear that quickly.</TD></TR></TABLE>
just 15,000 miles???
that's really bad... i'm in so much **** then... tires are expensive too!!!
anyone else have different outcome???
Old Apr 22, 2003 | 01:37 PM
del_parker's Avatar
Default Re: Camber Wear... how long will my tires last????? (PilotSi)
yeah, that toe will wear a tire out in like 1k or 2k miles if it was as off as mine was after i replaced the boots on my steering rack.
Old Apr 22, 2003 | 05:18 PM
VTECorona's Avatar
Mine are decently worn on the insides and I've had my setup in since last september and driven about 9k miles. Time for a skunk2 camber kit w\ 2 new front tires :\
DKYamada
Suspension & Brakes
12
Mar 21, 2009 06:29 AM
Tuesdaynightfever
31
May 24, 2006 06:03 AM
Arv
Nov 5, 2004 01:41 PM
bryandamatrix
Jul 10, 2004 12:32 PM
InfamousRS
Feb 14, 2002 07:31 AM
