Ok, so if i want to do LS vtec, and have a OBD 1 motor, can i buy a OBD 0 swap and make everything work? or can i just do it with a OBD1 to OBD0 harness? and if so, who makes a harness?
i am using an obd0 LS block bored out to 81.25 and an obd1 b16 head. it will work just fine.. if you run an ECU that looks for a knock sensor, then you will need to locate a spot for it on the obd0 ls block
haha, so id be able to use everything from the swap on my car? (OBD1 g2 integra) or would i have to use my distributor and all that insted of the b16 one?
