Help Car won't start, I have no spark....
Ok here's the setup, the motor is a b16a2 head from a 00 civic si, and a obd 1 gsr block (no crank fluc. sensor), ecu is a p72 hondata, only cel its throwing is code #6 which is low coolant (didn't put all the coolant in yet so this code make sense) other than code 6 no other codes. The distributor is from the 00 civic si as well. The motor cranks fine but there is no spark, i tested it by leaving a spark plug in the ignition wire while my friend cranked the car...no spark was jumping across. this is the same with all four wires.
Could a bad ground be causing the car not to fire?
Is the distributor bad?
Does it have to do with running a obd 1 block with a obd 2 head?
what procedures could i take to troubleshoot this?
thanx
thanx
i would go with your 2 top ideas. check for a bad ground, make sure your ground bolts are not painted and are not connected to a painted area. check the internals of the distributor for loose connections, and always remember to check fuses.
well fuses are all fine...can a bad ground prevent the motor from making any spark at all, i would think it would still fire just with a bad ground...no? what should i look for when i take the dist. cap off besides the coil connection? BTW thanks for the reply.
oh ****, what up josh...yeah i got everything in and i just finished putting the motor together, but now i have no spark. I don't even know where to begin with this one... i'm actually about to go out to my car in a little bit. Josh hit me up with a e-mail, i'll send you some pics of my project.
Xsi what do u mean a bad rotor?
Check all your grounds...Tranny to frame ground in very important for a car to start. If all else false borrow a friends dizzy for a few mins and try it out. Might be a bad ignitor, rotor, etc
ok well i checked the coil for power and i wasn't gettin any so i guess i need a new igntion coil...
also can i use any obd 2 b series distributor or does it have to be from a si. can i use a gsr, or ls to test if that was definitely my problem
ok little update guys....it was the ignition coil...car fired right up after i changed it, however i have a new problem....oil is spuing all over the place, not exactly sure where its comin from, time for a new thread!
billllll23integra
Apr 6, 2008 11:08 AM
aaronhume
25
Mar 22, 2005 08:42 PM
